How to automatically change the style after drag&drop UR
JSH2
Post by JSH2 »
To make hyprttext when I drag&drop a URL from internet explorer,
I use OnReadHyperlink and OnJump event as follows:
with RichViewEdit1 do begin
RTFReadProperties.UnicodeMode := rvruOnlyUnicode; //To use unicode
Options := Options + [rvoTagsArePChars];
AcceptDragDropFormats := AcceptDragDropFormats + [rvddURL];
Format;
procedure TForm1.RichViewEdit1ReadHyperlink(Sender:TCustomRichView;
const Target, Extras: string; DocFormat: TRVLoadFormat; var StyleNo,
ItemTag: Integer; var ItemName: string);
if DocFormat = rvlfURL then begin
StyleNo := cHyperLinkStyle;
ItemTag := Integer(StrNew(PChar(Target)));
procedure TForm1.RichViewEdit1Jump(Sender: TObject; id: Integer);
var URL: String;
RVData: TCustomRVFormattedData;
ItemNo: Integer;
RichViewEdit1.GetJumpPointLocation(id, RVData, ItemNo);
URL := PChar(RVData.GetItemTag(ItemNo));
ShellExecute(0, 'open', PChar(URL), nil, nil, SW_SHOW);
It works well.
But after drag&drop a URL, the textstyle remains the cHyperLinkStyle.
After drag&drop a URL, how could I automatocally change the textstyle to the previous textstyle?
Thanks in advance.
Not possible using "normal" methods (well, you can store the current text style and apply it in the next call of OnChange).
I suggest to implement switching to non-hypertext style when user presses space character.
