[Example] Smart indent
Smart indent, programming style
When user presses Enter key, this code adds space characters at the beginning of new paragraph (as many spaces as at the beginning of the current paragraph).
// Returns count of space characters at the beginning of the current paragraph
function GetLeadingSpacesCount(rve: TCustomRichViewEdit): Integer;
var StartItemNo, ItemNo, i: Integer;
    s: String;
  rve := rve.TopLevelEditor;
  ItemNo := rve.CurItemNo;
  while not rve.IsParaStart(ItemNo) do
    dec(ItemNo);
  Result := 0;
  StartItemNo := ItemNo;
  while ItemNo<rve.ItemCount do begin
    if (ItemNo>StartItemNo) and rve.IsParaStart(ItemNo) then
    if rve.GetItemStyle(ItemNo)<0 then
    s := rve.GetItemText(ItemNo);
    for i := 1 to Length(s) do
      if s[i]=' ' then
        inc(Result)
    inc(ItemNo);
// Returns string consisting of Count space characters
function GetSpaces(Count: Integer): String;
var i: Integer;
  SetLength(Result, Count);
  for i := 1 to Count do
    Result[i] := ' ';
// OnKeyDown, indenting
procedure TForm1.RichViewEdit1KeyDown(Sender: TObject; var Key: Word;
  Shift: TShiftState);
  if Key=VK_RETURN then begin
    RichViewEdit1.InsertText(#13+GetSpaces(GetLeadingSpacesCount(RichViewEdit1)));
    Key := 0;
Possibility to improve: when pressing Enter in the middle of paragraph, calculate how many space characters are to the right of the caret (so they will be at the beginning of the new paragraph) and take them into account.
2008-Dec-11: Updated for compatibility with TRichView 11 and Delphi 2009
Last edited by Sergey Tkachenko on Thu Dec 11, 2008 3:54 pm, edited 2 times in total.
Smart indent/unindent, MS Word style
This code changes FirstIndent and LeftIndent of paragraph, if Tab/Backspace is pressed when the caret is at the beginning of paragraph. First, it changes FirstIndent. Next, if FirstIndent is already changed, it changes LeftIndent.
This code changes indents only if the caret is at the beginning of non-empty paragraph.
When the caret is at the beginning of a bulleted/numbered paragraph, Tab increases the list level.
This code uses its own procedures for OnParaStyleConversion event. Of course, you can integrate this code in existing event handler instead. But in this way, it's easy to integrate this code in existing application, even if it uses RichViewActions.
// Procedure for OnParaStyleConversion event.
// Changes paragraph's FirstIndent to UserData
procedure TForm3.ChangeFirstIndentConversion(Sender: TCustomRichViewEdit;
  StyleNo, UserData: Integer; AppliedToText: Boolean;
  var NewStyleNo: Integer);
var ParaStyle: TParaInfo;
  ParaStyle := TParaInfo.Create(nil);
  ParaStyle.Assign(Sender.Style.ParaStyles[StyleNo]);
  ParaStyle.FirstIndent := UserData;
  ParaStyle.Standard := False;
  NewStyleNo := Sender.Style.ParaStyles.FindSuchStyle(StyleNo, ParaStyle,
    RVAllParaInfoProperties);
  if NewStyleNo<0 then begin
    Sender.Style.ParaStyles.Add.Assign(ParaStyle);
    NewStyleNo := Sender.Style.ParaStyles.Count-1;
  ParaStyle.Free;
// Changes paragraph's LeftIndent to UserData
// If UserData=0, resets FirstIndent as well.
procedure TForm3.ChangeLeftIndentConversion(Sender: TCustomRichViewEdit;
  ParaStyle.LeftIndent := UserData;
  if ParaStyle.LeftIndent=0 then
    ParaStyle.FirstIndent := 0;
  ParaStyle.Free;
function TForm3.ChangeIndent(rve: TCustomRichViewEdit;
  Step, Max: Integer): Boolean;
var OldParaStyleConversion: TRVStyleConversionEvent;
    FirstIndent, LeftIndent: Integer;
    ListNo, ListLevel, StartFrom: Integer;
    Reset: Boolean;
  Result := False;
  OldParaStyleConversion := rve.OnParaStyleConversion;
    if rve.SelectionExists then
    if  (rve.OffsetInCurItem<=rve.GetOffsBeforeItem(rve.CurItemNo)) and
       (rve.CurItemNo>0) and (rve.GetItemStyle(rve.CurItemNo-1)=rvsListMarker) then begin
       // changing list level
       rve.GetListMarkerInfo(rve.CurItemNo, ListNo, ListLevel, StartFrom, Reset);
       if (ListNo>=0) and (ListNo<rve.Style.ListStyles.Count) then
         if (Step>0) and (ListLevel+1<rve.Style.ListStyles[ListNo].Levels.Count) then begin
           rve.ChangeListLevels(+1);
           Result := True;
           end
         else if (Step<0) and (ListLevel>0) then begin
           rve.ChangeListLevels(-1);
           Result := True;
    if (rve.OffsetInCurItem>rve.GetOffsBeforeItem(rve.CurItemNo)) or
      not rve.IsParaStart(rve.CurItemNo) then
      exit; // not at the beginning of paragraph
    if (rve.OffsetInCurItem>=rve.GetOffsAfterItem(rve.CurItemNo)) and
      ((rve.CurItemNo=rve.ItemCount-1) or rve.IsParaStart(rve.CurItemNo)) then
      exit; // empty paragraph, exiting
    FirstIndent := rve.Style.ParaStyles[rve.GetItemPara(rve.CurItemNo)].FirstIndent;
    LeftIndent  := rve.Style.ParaStyles[rve.GetItemPara(rve.CurItemNo)].LeftIndent;
    if Step>0 then begin
      if FirstIndent=0 then begin
        rve.OnParaStyleConversion := ChangeFirstIndentConversion;
        rve.ApplyParaStyleConversion(Step);
        Result := True;
        end
      else begin
        inc(LeftIndent, Step);
        if LeftIndent>Max then
          LeftIndent := Max;
        if LeftIndent>rve.Style.ParaStyles[rve.GetItemPara(rve.CurItemNo)].LeftIndent then begin
          rve.OnParaStyleConversion := ChangeLeftIndentConversion;
          rve.ApplyParaStyleConversion(LeftIndent);
          Result := True;
      end
      end
    else begin
     if FirstIndent>0 then begin
        rve.ApplyParaStyleConversion(0);
        Result := True;
        end
      else begin
        if LeftIndent<0 then
          LeftIndent := 0;
        if (LeftIndent<rve.Style.ParaStyles[rve.GetItemPara(rve.CurItemNo)].LeftIndent) or
           (FirstIndent<>0) then begin
          Result := True;
    rve.OnParaStyleConversion := OldParaStyleConversion;
// OnKeyDown event
procedure TForm3.RichViewEdit1KeyDown(Sender: TObject; var Key: Word;
  if (Key=VK_BACK) and ChangeIndent(TCustomRichViewEdit(Sender), -48, 480) then
    Key := 0;
// OnKeyPress event
procedure TForm3.RichViewEdit1KeyPress(Sender: TObject; var Key: Char);
  if (Key=#9) and ChangeIndent(TCustomRichViewEdit(Sender), +48, 480) then
    Key := #0;
Upd: 2011-Jun-26: changing list levels on Tab
Upd: 2015-Jan-14: changing list levels on Backspace
Last edited by Sergey Tkachenko on Wed Jan 14, 2015 10:36 am, edited 3 times in total.
jonjon
Post by jonjon »
Sergey,
I've added this code and it seems to be working fine however I'm missing the SHIFT-TAB feature, available in Word, to un-indent.
Can it be easily added to your sample ?
Thanks.
This code unindents on BACKSPACE.
To add SHIFT+TAB, change
// OnKeyPress event
var step: Integer;
  if Key=#9 then begin
    step := 48;
    if GetAsyncKeyState(VK_SHIFT)and$8000<>0 then
      step := -step;
    if ChangeIndent(TCustomRichViewEdit(Sender), step, 480) then
      Key := #0;
jonjon
Post by jonjon »
Thanks Sergey but I can't get it to work on 13.10: TAB is working fine, Shift-Tab/Delete isn't. It looks like rve.IsParaStart is always returning false.
Sorry, I cannot reproduce this problem. I added TForm3.ChangeFirstIndentConversion and the code
var step: Integer;
    step := 48;
      step := -step;
      Key := #0;
in the ActionTest project, and it works on Tab and Shift+Tab as expected.
Note that this procedure works only in non-empty paragraphs, like in MS Word.
Rael Bauer
Post by Rael Bauer »
Sergey Tkachenko wrote:Sorry, I cannot reproduce this problem. I added TForm3.ChangeFirstIndentConversion and the code
var step: Integer;
    step := 48;
      step := -step;
      Key := #0;
If this is to work for Shift+Tab (i.e. un-indent) then shouldn't ChangeIndent function include some code like:
It seems the top part of the function is not handling both cases?
You are right, I corrected it.
