Save in Stream
Dieguuh
Save in Stream
Post by Dieguuh »
Hi.
I follow the demos and create one text editor, with some text format and support to internet links. It works fine, but when i try to save my documents in stream, this links disappear when a call they back to editor.
I'm follwing this steps:
- I'm saving my documents in a simple file and i call RichView.loadrvf() using that file.
All links and formatted words(Bold, size) are lost.
Can you send me a tutorial to help me with this?
Thx
1) Make sure that rvoTagsArePChars is included in Options
2) Make sure that rvoClearTagOnStyleApp is excluded from EditorOptions
Dieguuh
Post by Dieguuh »
The problem persist..
rvoTagsArePChars is included and rvoClearTagOnStyleApp is excluded.
The HyperLinks are working fine, but links and word formats isn't working.
You have a tutorial to help me?
thx
One more: right click th editor in Delphi, choose "Settings" in the popup menu, select "Allow adding styles dynamically".
Dieguuh
Post by Dieguuh »
I compare all the properties from demo editor's with my editor, and now its working fine.
Thx for help.
