Example for TableSort.pas?
DickBryant
Post by DickBryant »
Do you have an example project that uses TableSort.pas? I could probably muddle through how to apply it, but a working example would make the process a lot quicker :-) Belated Happy New Year, BTW!
Dick
What's the problem with using this unit?
var rvet: TCustomRichViewEdit;
    table: TRVTableItemInfo;
  if not RichViewEdit1.GetCurrentItemEx(TRVTableItemInfo, rvet, TCustomRVItemInfo(table)) then
  // display your modal form allowing choosing sort options
  // and column (in range 0..table.ColCount-1)
  SortCurrentTable(RichViewEdit1, Column, Ascending, IgnoreCase);
DickBryant
Thanks - exactly what I was looking for :-)
