Implement "Track changes" feature
AB
Post by AB »
For a multi-user software, I would like to have a "Track Changes" features, as in Word.
I tried to implement this in a very dirty way: every change is shown with an alternative style, colored.
It doesn't show deleted words or characters...
How can I implement this feature, without changing the TRichView core, or is this great feature in your to-do list?
Here is what I've done so far:
First I create a new Component with some new methods:
  protected
    StyleModif: array[0..31] of byte; // just 256 boolean values
    ModifItem: TCustomRVItemInfo;
    ModifItemOffset: integer;
  public
    // assign to a RichViewEdit for basic track changes:
    procedure ModifItemAction(Sender: TCustomRichView; ItemAction: TRVItemAction; Item: TCustomRVItemInfo;
      var Text: String; RVData: TCustomRVData);
    procedure ModifCaretMove(Sender: TObject);
    // track changes text styles: GetBit(@StyleModif,StyleNo)=true, BackColor=clYellow
    function StyleModifToNormal(StyleNo: integer): integer;
    function StyleNormalToModif(StyleNo: integer): integer;
    // Tag=integer(NewStr('Comment')) (must have rvoTagsArePChars in Options)
Then the implementation part, with dirty StyleNo changes:
procedure TIct4RichViewEdit.ModifCaretMove(Sender: TObject);
var s,s2,s3: string;
    m: TRVTextItemInfo;
    i, e,b, o, L: integer;
    rv: TCustomRichViewEdit absolute Sender;
  if (ModifItem=nil) or not (Sender is TCustomRichViewEdit) or
    not (ModifItem is TRVTextItemInfo) then exit;
  while (rv.InplaceEditor<>nil) and (rv.InplaceEditor is TCustomRichViewEdit) do
    rv := TCustomRichViewEdit(rv.InplaceEditor);
  m := TRVTextItemInfo(ModifItem);
  ModifItem := nil;
  i := rv.GetItemNo(m);
  if i<0 then exit;
  s := rv.GetItemTextA(i);
  L := length(s);
  e := ModifItemOffset;
  b := e;
  while (e<=L) and (s[e]<>' ') do inc(e); // word modified in s[b+1..e-1]
//    while (e<=L) and (s[e]=' ') do inc(e); / includes spaces after
  while (b>0) and (s[b]<>' ') do dec(b);
  if e=b then exit;
  dec(e);
  s2 := copy(s,b+1,e-b);
  s3 := copy(s,e+1,maxInt);
  o := rv.GetOffsBeforeItem(i);
  inc(b,o);
  inc(e,o);
  inc(o,ModifItemOffset-b+1); // ModifItemOffset will change with ApplyTextStyle
  if rv.UndoAction=rvutDelete then begin
    dec(o,2);
    if o<1 then o := 1;
  rv.SetSelectionBounds(i,b,i,e);
  rv.ApplyTextStyle( StyleNormalToModif(m.StyleNo));
  i := rv.CurItemNo;
  rv.SetSelectionBounds(i, o, i, o);
  rv.Invalidate;
procedure TIct4RichViewEdit.ModifItemAction(Sender: TCustomRichView;
  ItemAction: TRVItemAction; Item: TCustomRVItemInfo; var Text: String;
  case ItemAction of
    rviaTextModifying: begin
      if (ModifItem=Item) or (Item.StyleNo<0) or GetBit(@StyleModif,Item.StyleNo) or
        not Sender.InheritsFrom(TCustomRichViewEdit) then exit;
      ModifItem := Item;
      ModifItemOffset := TCustomRichViewEdit(Sender).OffsetInCurItem;
function TIct4RichViewEdit.StyleModifToNormal(StyleNo: integer): integer;
var FontSource: TFontInfo;
  FontSource := Style.TextStyles[StyleNo];
  if FontSource.BackColor<>clYellow then
    result := StyleNo else
    result := FontSource.BaseStyleNo;
function TIct4RichViewEdit.StyleNormalToModif(StyleNo: integer): integer;
var FontSource, FontInfo: TFontInfo;
  if FontSource.BackColor=clYellow then begin
    result := StyleNo;
  FontInfo := TFontInfo.Create(nil);
    FontInfo.Assign(FontSource);
    FontInfo.BackColor := clYellow;
    FontInfo.BaseStyleNo := StyleNo;
    result := Style.TextStyles.FindSuchStyle(StyleNo,FontInfo,RVAllFontInfoProperties);
    if result=-1 then begin
      with Style.TextStyles.Add do begin
        Assign(FontInfo);
        Standard := false;
      result := Style.TextStyles.Count-1;
      SetBit(@StyleModif,result);
    FontInfo.Free;
The StyleModif just check whatever the Style is a "modifying" Style or not with this common and fast procedures:
function GetBit(p: pointer; aIndex: integer): boolean;
asm
  bt      [p],aindex  // eax = self = bits
  sbb     eax,eax
  and     eax,1
procedure SetBit(p: pointer; aIndex: integer);
asm
  bts [p],aIndex
Sorry, this feature is not planned in near future.
The simplest way to implement is using OnKeyDown, OnKeyPress, OnPaste to trap editing operations.
For example, the user pressed Backspace. You use OnKeyDown to prevent the default action, but apply the special style to the character to the left instead.
Unfortunately, I do not know what to do with modifying line breaks and with non-text items in this case.
AB
Post by AB »
Thanks for the answer, and the 'On*' trick: I just made up something complicated.
If I manage to implement this feature, I will post here the code.
DeepBlue7911
mark
Post by DeepBlue7911 »
mark
