Deleting Blank Lines
Richard King
Post by Richard King »
How to delete blank lines?
The following code works:
rvP1.DeleteSelection;
if rvP1.GetCurrentItemText = '' then
rvP1.DeleteParas(rvP1.CurItemNo, rvP1.CurItemNo);
BUT not when selection is in a table cell (previously the code has done a rvP1.SearchText( 'some text', [rvseoDown] ).
How to write something which will work inside and outside a table ??
Yernar Shambayev
Post by Yernar Shambayev »
see InplaceEditor
Should it be an editing operation (that can be undone/redone by user)?
If not, the code is below:
procedure DeleteBlankLines(RVData: TCustomRVData);
var i,r,c: Integer;
    table: TRVTableItemInfo;
  for i := RVData.ItemCount-1 downto 0 do
    if RVData.IsParaStart(i) and (RVData.GetItemStyle(i)>=0) and
      (RVData.GetItemText(i)='') and (RVData.ItemCount>1) then
      RVData.DeleteItems(i,1)
    else if RVData.GetItemStyle(i)=rvsTable then begin
          if table.Cells[r,c]<>nil then
            DeleteBlankLines(table.Cells[r,c].GetRVData);
Call:
DeleteBlankLines(RichView1.RVData);
RichView1.Format;
Last edited by Sergey Tkachenko on Tue Sep 06, 2005 8:53 pm, edited 3 times in total.
Richard King
fix to code above
Thanks Sergei - works great -- but note
the line rv.DeleteItems(i,1) needs to be
rvData.DeleteItems(i,1)
Thank you, I fixed the code
I modified the code: added the condition (RVData.ItemCount>1), to prevent deleting the last RVData item.
It's ok to delete all items from TRichView.
It's ok to delete all items from TRichViewEdit (one empty line will be readded by Format).
But it's not ok to delete all items from table cells.
