I install RichView and Addict and RVActions separately with no problem. However, Actions and Addict have a problem with each other. Here is the message I get when d2005 starts:
Cannot load package 'addict_d9.' It contains unit 'ad3MainDictionary,' which is also contained in 'rvActionsD9'.....
I will try the latest RV and Actions when I get access to private group. I am a registered user.
Problems installing Actions and D2005
Unistall the RichViewActions' packages, delete their *.bpl and *.dcp files.
Open rvActionsRunD9.dpk. Highlight "requires", and add (using context menu) addict_d9 and Addict_RichView_d9 there (both these packages must be already installed). Save rvActionsRunD9.dpk. Install the RichViewActions' packages again.
Installation problem solved
Did steps you suggested and it worked, thanks!
