[Example] How to combine several documents in one
procedure AddDoc(const FileName: String; rv: TCustomRichView);
var Stream: TFileStream;
  Stream := TFileStream.Create(FileName, fmOpenRead);
  rv.InsertRVFFromStream(Stream, rv.ItemCount);
  Stream.Free;
  RichView1.Clear;
  RichView1.DeleteUnusedStyles(True, True, True);
  AddDoc('c:\file1.rvf', RichView1);
  AddDoc('c:\file2.rvf', RichView1);
  AddDoc('c:\file3.rvf', RichView1);
  RichView1.Format;
If you want to add page breaks between documents, use the following code
  ItemCount: Integer;
  ItemCount := rv.ItemCount;
  Stream.Free;
  if (ItemCount>0)  and (ItemCount<rv.ItemCount) then
    rv.PageBreaksBeforeItems[ItemCount] := True;
Last edited by Sergey Tkachenko on Fri Aug 24, 2007 5:12 pm, edited 1 time in total.
Guest
Post by Guest »
Hello Sergey,
How can I combine several RTFs into a single file - the example is only for RVFs & I cannot see any procedure like InsertRTFFromStream...
Thanks,
Fiachra
Guest
Post by Guest »
Don't worry about that question Sergey,
I've gotten around it by loading my RTFs (one at a time) into a RichView and saving them as RVFs which I then load as per your original example. It's a bit convoluted but it works!
Thanks anyway,
Fiachra
It's not necessary. You can use LoadRTF/LoadRTFFromStream.
Unlike LoadRVF/LoadRVFFromStream they
- do not clear trichview,
- cannot replace collection of styles, they can only add new styles.
So you can use them to load several documents.
