How to create/modify RTF text inside a browser (web based)
I use RichView inside my win32 application to fill document in a database. So I have a lot of fields in RTF format. Now I must develop a web based interface for this application than can display and of course update these fields...
No problem for displaying RTF text, the TrichView is so great that I can easyly convert RTF into HTLM. But How can I update them ? I can convert RTF into plain text and then Text to RTF but Im going to lose all the styles, pictures, ...!
Do someone knows a way or a component that can update RTF text inside a browser (ActiveX version of TRichView, full javascript, Flash..., java, OLE ??) like a web based RTF editor ?
Michael
Michael
Sergey Tkachenko wrote:You can create ActiveX editor based on TRichView.
Create an ActiveX project in Delphi, add ActiveForm, place RichViewEdit and RVStyle on this form, toolbar, etc.
Sergey:
Could you add this this explanation of how to use RichView inside a browser to the Examples/Demos forum, so that it will be easy to find again. Thanks.
Louis
Ok Thank You!
This seems to work great, but I do not know how to load text from the database inside of the ActiveX and of course how to retreive the updated text when the user post de html form ? Do you know where I can get some tips about that, or do you have a more precise idea/example ?
Thanks a lot!
Michael
Thanks a lot!
Michael
FYI, Im getting started with that... Ive just done what you say with the ActiveX application. I add it in a web page like this:
I can, with the param RTF, initialize the RichEdit component... and then when I submit the html form, I take the rtf text from the activeX to an input field with a javascript code like this one:
For now, the ActiveX is working fine on my computer but I cannot yet make it working outside mine... I dont know yet why, maybe security problems... or registering problems...
Thank you for your help!
Michael
<OBJECT type="application/x-oleobject" id="XMEMOObj" name="XMEMOObj" width="100%" height="100%" classID="CLSID:F35D9239-62C6-4BE1-AB55-15980ED1840A" codebase="http://test/rte/MOSMemo.ocx#1,0,0,0">
<param name="LPKPath" value="/rte/memo.lpk"/>
<param name="RTF" value="blabla"/>
</OBJECT>
aHiddenInputField.value = XMEMOObj.RTF;
document.MainForm.submit(); return false;
Michael
