Hi!
How could I change the filename after Importing a *.DOC ??
To see it when I close the APP and the question appers "Save changes in xxx?"
Thanks!!!!
Stevie
Changing filename automatic after Import...
If you want to change file name for new documents, use RVAControlPanel.DefaultFileName (change it before execution of TrvActionNew).
If you want to change file name for document with assigned name (assigned after executing TrvActionOpen or TrvActionSaveAs), you can use TrvActionSave.Documents:
TrvaDocumentInfo(rvActionSave1.Documents[rvActionSave1.FindDoc(RichViewEdit1)]).FileName := ...
Thanks!Sergey Tkachenko wrote:If you want to change file name for new documents, use RVAControlPanel.DefaultFileName (change it before execution of TrvActionNew).
If you want to change file name for document with assigned name (assigned after executing TrvActionOpen or TrvActionSaveAs), you can use TrvActionSave.Documents:Code: Select all
Excellent Help!
