Access Violation using table
Mauro
Post by Mauro »
I've compiled the Demos/Delphi/Editors/Editor1 without any change and I'm having an AV when exit the caret from a table cell.
Is it a known issue?
Tks again.
Mauro.
It's a known problem, if you use version 1.9.8 and Delphi 2005.
If yes:
- if you are a registered TRichView version, update your copy of TRichView to the newer version;
- if you use a trial version, send me e-mail, I'll send you a fixed version.
