Need help for save and restore the page properties
Andy
Post by Andy »
Please tell me,
What is the correct way to save and restore the document.
So that the document will be loaded as they would at least saving or leaved.
Andy
Andy
Post by Andy »
I see a 3 different structures for layout but I don't know which is the right one.
When I set some property the whole layout is destroyed.
Attention: it's for ScaleRichView !
Andy
SRichViewEdit1.RichViewEdit.SaveRVFToStream/SaveRVF and
SRichViewEdit1.RichViewEdit.LoadRVFFromStream/LoadRVF.
As for the layout question, I do not understand. Please give more details.
Andy
Post by Andy »
For saving I use your suggested method. -> SaveRVF
For loading I have troubles:
With "SRVE.RichViewEdit.LoadRVF(FNAme)"
I get an exception out of maximun (-1)
class TCustomRVData; unit-> CRVData.pas
always on the second try , it works.
But with "rvActionsResource.rvActionOpen1.LoadFile" it worky always.
What is the difference ?
Andy
Do you call SRVE.RichViewEdit.Format after LoadRVF?
Andy
Post by Andy »
:oops: Shame over me,
yes,I have forget format-method.
Sorry.
But now back to my problem.
In the layout - sructure all is ok (by loading), but it will not restore by loading document. (Missing update PageProperty)
What have forget now ?
Do you save in RVF format?
What's you version of ScaleRichView?
Are rvfoSaveDocProperties and rvfoLoadDocProperties included in SRVE.RichViewEdit.RVFOptions? (must be by default)
Andy
Post by Andy »
Yes,I save in RVF Format.
Version ScaleRichViw is 1.5.1
Load/Save Docproperties are TRUE
In debugger I see that the Margins will correct save and correct loaded.
But this parameter will not activatet to the pageproperty.
Andy
Post by Andy »
When direct after: SRVE.RichViewEdit.LoadRVF(FileName);
I wrote this code
SRVE.SetMargin(SRVE.RichViewEdit.LeftMargin ,
SRVE.RichViewEdit.TopMargin ,
SRVE.RichViewEdit.RightMargin,
SRVE.RichViewEdit.BottomMargin);
Then all is fine.
But I have think my ScaleRichView-component make this automatically !
Or really not ?
Try updating to 1.5.2 and check if the problem persists.
Unfortunately, SRVE cannot update margins automatically after calling SRVE.RichViewEdit.LoadRVF.
You need to call
SRVE.RichViewEdit.LoadRVF(...); // or LoadRTF
SRVE.SetRVMargin;
SRVE.Format;
Or you can call
SRVE.LoadRVF(...);
SRVE.Format;
