I can't save a RichView into a Field
perellopis
Post by perellopis »
Hi.
I have a batch importing from HTML mails, using a RVHtmlImporter and a RichView.
I save every imported file using a stored procedure :
ImportMessageToRichView;
spEmail.Prepare;
spEmail.ParamByName('FROM').AsString := Msg.From.Address;
spEmail.ParamByName('FOR').AsString := Msg.Recipients.EMailAddresses;
spEmail.ParamByName('DATE').AsDateTime := Msg.Date;
spEmail.ParamByName('ABOUT').AsString := Msg.Subject;
Stream := TMemoryStream.create;
  RichView1.SaveRVFToStream(Stream, False);
  Stream.Seek(0, soFromBeginning);
  spEmail.ParamByName('MESSAGE').LoadFromStream(Stream);
  Stream.Free;
spEmail.ExecProc;
But when I try to view this html mails, in a TDBRichEdit, I don't get the message, I get his hexadecimal content. Someting like :
-8 1 3
-9 0 0 0 0 0 7
1 1 0 0 0 0
0 1 -1 1 0 0
Tropical News [mailto:[email protected]]
1 1 0 0 0 0
Sended:
0 1 -1 1 0 0
lunes, 03 de noviembre de 2008 16:12
1 1 0 0 0 0
For:
0 1 -1 1 0 0
[email protected]
1 1 0 0 0 0
About:
0 1 -1 1 0 0
Specia Packl 5 + 1
-60 3 1 0 2 0
1
4
¿ What am I doing wrong ?
Thank you.
It is saved, but loaded as a plain text, because reading in RVF format failed.
It happens because the document was saved without text, paragraph and list styles. In this mode, it can be loaded only to TRichView having exactly the same collections of styles.
To fix this problem, double click RichView1 in Delphi, choose "Settings" in the popup menu and select "allow adding styles dynamically".
perellopis
Thank you, now it works nicely.
StevieO
Post by StevieO »
Sergey Tkachenko wrote:It is saved, but loaded as a plain text, because reading in RVF format failed.
How to do this with SRichView ???
I've the same Problem...
Make sure that DBSRichViewEdit.RVFOptions property includes rvfoSaveTextStyles and rvfoParaStyles, and
DBSRichViewEdit.RVFTextStylesReadMode = DBSRichViewEdit.RVFParaStylesReadMode = rvf_sInsertMerge.
StevieO
Post by StevieO »
Sergey Tkachenko wrote:Make sure that DBSRichViewEdit.RVFOptions property includes rvfoSaveTextStyles and rvfoParaStyles, and
Must I use the TDBSRichViewEdit ???
Could not use the TSRichViewEdit ???
I dont need the direkt datalink from TDBSRichViewEdit... ???
Thanks!
You can use TSRichViewEdit.RichViewEdit.SaveRVFToStream to save to the field.
StevieO
Post by StevieO »
Sergey Tkachenko wrote:You can use TSRichViewEdit.RichViewEdit.SaveRVFToStream to save to the field.
The Parameters are OK!
Yes of course but there is the problem with the data:
-8 1 3
-7 0 -1 0 0 0 0 -16777211
-9 2 0 0 2 0 1
Style
