PrintSetup problem
Yann
PrintSetup problem
Post by Yann »
The page is not correctly refresh after a Page Setup. The text is out of the page.
You can try it :
- Run the demo "RichView Actions Test" (demo of ScaleRichView - \ScaleRichView\Demo\ActionTest\)
- Open "File/New" menu
- Add a text in the page
- Open "File/Page setup..." menu
- set "1" to the margin left field.
I can give you a print screen.
I work with D7, TRichView 10.4, and TScaleRichView 1.5.2 and RVA 1.65
Thanks for your help.
Yann
Yann
Post by Yann »
How can I solve it ?
Yann
The bug is confirmed. Notice that after the further editing the text is moved to the proper position.
Will be fixed in the next update.
Yann
Post by Yann »
Thanks,
Congratulation for your work
Yann
proxy3d
ScaleRichView Developer
Post by proxy3d »
The bug is fixed in version 1.7.0
