TRichViewXML : SaveToStream ... LoadFromStream
jclaes
Post by jclaes »
I'm trying to copy the data from one RichViewEdit to another using RichViewXML.SaveToStream / .. LoadFromStream.
The destination RVE stays empty . How come ??
aStream : TStringStream ;
aString : String ;
T: TXMLTree;
MainRoot, DocRoot: TXMLTag;
// SaveToStream
T := TXMLTree.Create(RichViewXML1.Encoding);
T.Items.AddTag(RichViewXML1.RootElement, T, T);
MainRoot := T.Items[0];
MainRoot.Items.AddTag('Data', T.Items[0], T);
DocRoot := MainRoot.Items[MainRoot.Items.Count-1];
RichViewXML1.RichView := RichViewEdit1;
RichViewXML1.SaveToXML(DocRoot);
aStream := TStringStream.Create('') ;
T.SaveToStream(aStream,true);
T.Free;
// LoadFromStream
T.LoadFromStream(aStream);
RichViewXML2.RichView := RichViewEdit2;
MainRoot := T.Items.FindTagOfName(RichViewXML2.RootElement);
if MainRoot<>nil then
DocRoot := MainRoot.Items.FindTagOfName('Data');
if DocRoot<>nil then
RichViewXML2.LoadFromXML(DocRoot);
T.Free;
RichViewEdit2.Format ;
Ar4i
Post by Ar4i »
To make your code more readable warp it in CODE tags.
To solve your problem you can try using InsertXXXFromStream instread of LoadFromXXX. At least thi method works fine with not XML RichView components.
jclaes
Post by jclaes »
When I use the InsertFromStream i get a 'no root element error'
[/code]
Try setting aStream.Position := 0 before loading from this stream.
jclaes
Post by jclaes »
Sorry but still not working.
here is the code
  aString : String ;
  T: TXMLTree;
  // SaveToStream
   T.Free;
// LoadFromStream
 aStream.Position := 0 ;
 RichViewXML2.InsertFromStream(aStream);
   T.Free;
arnfinn
InsertFromStreamEd
Post by arnfinn »
Hi!
I have the same problem. The destenation is empty.
Code:
Source.SaveRTFToStream(Stream, False);
Stream.Position := 0;
stream.SaveToFile('C:\streamtest.txt');
Dest.InsertRTFFromStreamEd(Stream);
Dest.Format;
Please send a sample project to reproduce.
(PS: Format is not needed after InsertRTFFromStreamEd)
arnfinn
RichView
Post by arnfinn »
Hi!
I hvae a sample file. Wher do I send it??
Arnfinn.
arnfinn
Post by arnfinn »
Her is the code. I have made a DBRichView and the purpose is to copy from one to the other with the help of stream. I see that the stream has data butt the destination is empty. it is the line
that is the problem. Dest is empty.
Can you pleas help?
procedure TForm1.cxButton2Click(Sender: TObject);
  ItemNo,
  Offset: Integer;
  Stream: TMemoryStream;
  Source,
  Dest:   TDBRichViewEdit;
  frm:    TForm;
  sStyle: TRVStyle;
    frm    := TForm.Create(nil);
    sStyle := TRVStyle.Create(frm);
    Dest := TDBRichViewEdit.Create(frm);
    Dest.Parent := frm;
    Dest.Style := sStyle;
    Dest.DataField  := 'INFODATA';
    Dest.Datasource := dsTo;
    Source := TDBrichViewEdit.Create(frm);
    Source.Parent := frm;
    Source.Style := sStyle;
    Source.DataField  := 'INFODATA';
    Source.Datasource := dsFrom;
    if (dsTo.DataSet.Bof and dsTo.DataSet.Eof) then
      dsTo.DataSet.Insert;
    end else
      dsTo.DataSet.Edit;
    ItemNo := Dest.ItemCount -1;
    Offset := Dest.GetOffsAfterItem(ItemNo);
    Dest.SetSelectionBounds(ItemNo, Offset, ItemNo, Offset);
    Dest.Format;
    FreeAndNil(Dest);
    FreeAndNil(Source);
    FreeAndNil(sStyle);
    FreeAndNil(frm);
    FreeAndNil(Stream);
    cxPageControl1.ActivePage := DBRichView_Dest;
[/code]
From the first sight, the code looks correct. I need a sample project that I can compile to reproduce the problem.
arnfinn
Post by arnfinn »
Hi!
Give me an email address and I will send it to you.
Thx.
richviewgmailcom
arnfinn
Post by arnfinn »
you got m@il.
Arnfinn
Received. I'll check it tomorrow.
You insert RTF in Dest, but then you destroy Dest without posting to a database.
Instead of Dest.Format, call dsTo.DataSet.Post.
