spaces which make a memo-text justify are white,
j&b
Post by j&b »
If memo (rve) is focused memo.color is clYellow.
If grid is focused memo.color is clInfoBk.
The spaces which make memo-text justify (Blocksatz) are white, but they shall have the same color as memo.color (clYellow or clInfoBk).
2.
If memo has blank lines at the end, you have in the preview (or printing) a 2. page though she is empty. I look to the end of the memo for blank lines and delete them, an user doesn't do so. How can I delete them by programm (e.g. memo.exit).
I hope someone can help me.
Jürgen
1. I cannot reproduce the problem with spaces. Please send me a project showing it.
2.
procedure DeleteTrailingBlankLines(RVData: TCustomRVData);
var i: Integer;
  for i := RVData.ItemCount-1 downto 1 do
    if RVData.IsParaStart(i) and (RVData.GetItemStyle(i)>=0) and
      (RVData.GetItemText(i)='') then
      RVData.DeleteItems(i,1)
      break;
Call:
DeleteBlankLines(RichViewEdit1.RVData);
RichViewEdit1.ClearUndo;
RichViewEdit1.Format;
j&b
spaces which make memo-text justify are white
Post by j&b »
Hello Sergey,
1. Thank for your help.
2. Sorry. I hope you can understand my problem now.
When I leave memo to focus grid memo.color changes to clInfoBk.
The spaces (between chars) in a memo which make memo-text justify (zum Blocksatz) are white (but they shall be clYellow (or clInfBk)).
Jürgen
I still cannot reproduce the problem. In my tests, these spaces are not visible (transparent) if the corresponding TextStyles.BackColor = clNone, as it should be.
