[Example] How to store HTML in database
TDBRichViewEdit can store data in the following formats: RVF, RTF, text, depending on the value of FieldFormat property.
If you store data in another format, such as HTML, you need to process OnSaveCustomFormat and OnLoadCustomFormat events.
Example 1: using TrvHtmlImporter
procedure TForm1.DBRichViewEdit1SaveCustomFormat(Sender: TCustomRichView;
  Stream: TStream; var DoDefault: Boolean);
  Sender.SaveHTMLToStreamEx(Stream, ExtractFilePath(Application.ExeName),
    'title', 'img', '', '', '', []);
  or
  Sender.SaveHTMLToStream(Stream, ExtractFilePath(Application.ExeName),
    'title', 'img', []);
  DoDefault := False;
procedure TForm1.DBRichViewEdit1LoadCustomFormat(Sender: TCustomRichView;
var s: String;
  SetLength(s, Stream.Size);
  Stream.ReadBuffer(PChar(s)^, Length(s));
  RvHtmlImporter1.LoadHtml(s);
  DoDefault := False;
If your documents have images, this example stores them in the application directory (with autogenerated names, so there will be many unused images). You can process OnImportPicture and OnSaveImage2 events to store them in database instead.
Example 2: using TRvHtmlViewImporter:
All the same, except for
var s: String;
  HTMLViewer1.LoadFromStream(Stream);
  RVHTMLViewImporter1.ImportHtmlViewer(HTMLViewer1, Sender as TCustomRichViewEdit);
  DoDefault := False;
Re: [Example] How to store HTML in database
This example is obsolete.
Since TRichView v21, this is a built-in feature. It does not require additional HTML importer components. Just assign DBRichViewEdit.FieldFormat = rvdbHTML.
