ppPDFRendererRV - Huge text
JPR
Post by JPR »
Hello Sergey,
I'm trying to use TRichView and the wrapper for ReportBuilder.
I added the unit ppPDFRendererRV to have Richtexts as text and not as image.
It's working but in my PDF File the richtexts are huges.
The text is bigger in the PDF File than in preview mode.
Can you help me on this ?
JP
This is a known problem, it happens when saving document loaded from archive (instead of saving document from a report designer)
I am working on solving it.
JPR
Post by JPR »
Hello Sergey,
Thanks a lot.
Just a question about the date for next release ?
Thanks again.
Unfortunately, PDF generation in RB has some important problems that makes ppPDFRendererRV useless, even if I fix this problem.
We are working with Digital Metaphors to solve these problems, but I do not know how soon it will be fixed, because it depends not only on me.
