I have a problem whit Tables
rocoed
Post by rocoed »
have the following case:
I insert a table in a DBRichviewedit component, then, I add 3 rows. one of these rows have about 100 records. The other two rows have about 10 records each. When I make a preview on rvprintpreview component, I get a row per page, and the first row only display the records that fits on the first page, and the rest of the 100 records are missing, and don't appear on the next page. In the next
page I get the 2nd and 3rd row of the tabel.
The row can't be printed using 2 o more pages?. How can I chage that?
Yernar Shambayev
Post by Yernar Shambayev »
yes, this is a problem.
Yes, this is a limitation of the current version of TRichView.
I plan to fix it in very near future
rocoed
ok, Thanks
Post by rocoed »
I will wait the next version...
tmMK
Post by tmMK »
i have a similar problem with large items (tables) in print preview... when do you plan to release fixed version?
thanks
