Disable shortcut keys (Shift+Delete, Ctrl+X etc.)
kolovan
Post by kolovan »
is there any way to disable shortcut keys (Shift+Delete, Shift+Insert, Ctrl+Insert, Ctrl+X, Ctrl+C, Ctrl+V) in RichViewEdit except writing code for OnRichViewEditKeyDown event handler?
No. Only using OnKeyDown.
Or Form.OnKeyDown + Form.KeyPreview=True, but it is essentially the same thing.
Or placing menu items or actions with these shortcuts.
But there are no RichViewEdit properties to disable processing these keys.
kolovan
Post by kolovan »
Thank you, Sergey!
