Addict Spell check in UNICODE text
AHEJN
Post by AHEJN »
I try to add spell checker to a french text editor, but in some case, it fails to action. It usually happens when an accent such as "Considérant " . when the char is "é", it works correctly, if the char is "e", the suggestion a is empty.
It looks like this is an Addict3 problem.
For any case, try checking the same word in TMemo.
AHEJN
Post by AHEJN »
Tried, the same problem in TMemo, waiting for the update for Addict. It's difficult to find a spell-checker that supports French.
Thanks for your reply.
