Copy hole table
Guest
Copy hole table
Post by Guest »
How can I select and copy the hole table in my document?
I use 1 document as template. And the document is filled by the source code with data from a dataset.
For each record I want copy a table which is defined already in the template document.
How can I select the total table and copy it to a position in another table.
{somethin like:
for lCnt:=0 to aDataset.RecordCount do
SelectTable();
CopyTable();
FillTableByRecord();
end;}
Do you want to copy cells of one table in cells of another table?
Guest
Post by Guest »
I want to copy the table totally.
I have 1 main table. In each row I want to copy the table which is in the template document in the main table in cell [0,0]
The table in cell 0,0 I want to copy to cell[1,0] of the same maintable
sourcetable.SaveToStream(Stream);
desttable := TRVTableItemInfo.CreateEx(1,1, rv.RVData);
Stream.Position := 0;
desttable.LoadFromStream(Stream);
Stream.Free;
<insert desttable where you want)
