Insert new text and keeping the selecion
Prometeus
Post by Prometeus »
I need to do some processing in a selected text and after that (the text will have the same length as before) keep the selection. I tried doing that:
rv.Format;
rv.GetSelectionBounds(StartItemNo,StartItemOffs,EndItemNo,EndItemOffs,false);
work_str := rv.GetSelText;
(Do some text processing on 'work_str')
rv.InsertText(work_str,true);
rv.Format;
rv.SetSelectionBounds(StartItemNo,StartItemOffs,EndItemNo,EndItemOffs);
Unfortunatelly this did not work. I tried looking other topics about similar situation but found nothing. How can I do that?
Thanks for any help.
Use the function from RVLinear.pas: http://www.trichview.com/help/idh_rvlinear.html
Prometeus
Post by Prometeus »
Hello, Sergey,
It worked perfectly!
Thanks!
