Format not woking
Format not woking
It's been a while since i have work with TRichview, but now, it seems i have to update some stuff. I did my software on D2007 and ive upgrade to D2010. I did download the new files from your site and installed the components. Everything was fine to compile and run, but we didnt really used the TRichview. Lately, someone told me the TRichview was doing wierd thing so there is my problem:
When i load my saved document (LoadRVFFromStream) my document is not paint. I dont understand because i have SRichView1.Format and i tried SRichView1.RichViewEdit.Format and nothing works. (I have to scroll with the mouse button to make it draw my document)
The other problem is: I have custom components in my document and those are not loaded. I did create TRVChartItemInfo(rvsChart = -13), TRVChiffrierItemInfo (rvsChart = -14), etc.. And none of those are loaded but they work fine when i add them. I did used RegisterRichViewItemClass(rvsChart,TRVChartItemInfo);
to register them.
I did tried the SaveHTML and it work fine. so Is it SaveRVFToStream or LoadRVFToStream that doesnt work.
Thanks for helping me.
GoToXY
to register them.
GoToXY
i did a simple application. Adding a SRichViewEdit to my form, adding 2 buttons (load and save)
Button1 = SRV.RichViewEdit.SaveRVF('C:\Test.rvf');
Button2 = SRV.LoadRVF('C:\Test.rvf'); SRV.Format;
Anytime i save something and i load it, it dont redraw. i always have to scroll the document to get a repaint.
On the other hand, i did donwload the demo for scaleRichView and i did load the readme.rvf that was in and it did repaint normaly. I must say that this really confused me more.
hope you know why those things are happening.
Thanks again
GoToXY
Thanks again
GoToXY
Send the file to [email protected]
I did used the one of your component to create my, i did copy it and made some changes to my needs.
unit ChartRV;
interface
Uses Classes, Windows, Graphics, Controls, SysUtils, RVItem, DB, RVClasses,
RVStyle, RVScroll, DLines, RVTypes, RVFuncs, Jpeg, Dialogs, FMTBcd,
Uni, InfoDB;
{$I EnerConst.pas}
Const
rvsChart = -13;
Type
THackRVRectItemInfo = class(TRVRectItemInfo);
TRVChartItemInfo = class(TRVRectItemInfo)
Protected
{$IFNDEF RVDONOTUSEANIMATION}
FAnimator: TObject;
{$ENDIF}
FResizable: Boolean;
FNoChart : Integer;
function GetHeight: Integer; override;
function GetWidth: Integer; override;
function GetRVFExtraPropertyCount: Integer; override;
procedure SaveRVFExtraProperties(Stream: TStream); override;
Function GetChartImage(NoChart:Integer):TMetaFile;
Public
Image,ImageCopy : TGraphic;
ImageWidth, ImageHeight, Interval : Integer;
NoHTMLImageSize: Boolean;
Alt, ImageFileName: String;
Constructor CreateEx(RVData: TPersistent; NoChart:Integer; AVAlign: TRVVAlign); virtual;
Constructor Create(RVData: TPersistent); override;
Function PrintToBitmap(Bkgnd: TBitmap; Preview: Boolean; RichView: TRVScroller; dli: TRVDrawLineInfo; Part: Integer; ColorMode: TRVColorMode):Boolean;override;
Procedure Print(Canvas: TCanvas; x,y,x2: Integer; Preview, Correction: Boolean; const sad: TRVScreenAndDevice; RichView: TRVScroller; dli: TRVDrawLineInfo; Part: Integer; ColorMode: TRVColorMode; RVData: TPersistent); override;
procedure Assign(Source: TCustomRVItemInfo); override;
procedure TransferProperties(Source: TCustomRVItemInfo; RVData: TPersistent); override;
function SetExtraIntProperty(Prop: TRVExtraItemProperty; Value: Integer): Boolean; override;
function GetExtraIntProperty(Prop: TRVExtraItemProperty; var Value: Integer): Boolean; override;
function SetExtraStrProperty(Prop: TRVExtraItemStrProperty; const Value: String): Boolean; override;
function GetExtraStrProperty(Prop: TRVExtraItemStrProperty; var Value: String): Boolean; override;
procedure UpdatePaletteInfo(PaletteAction: TRVPaletteAction; ForceRecreateCopy: Boolean; Palette: HPALETTE; LogPalette: PLogPalette); override;
function GetMinWidth(sad: PRVScreenAndDevice; Canvas: TCanvas; RVData: TPersistent): Integer; override;
destructor Destroy; override;
function AsImage: TGraphic; override;
procedure Paint(x,y: Integer; Canvas: TCanvas; State: TRVItemDrawStates; Style: TRVStyle; dli: TRVDrawLineInfo); override;
function GetBoolValue(Prop: TRVItemBoolProperty): Boolean; override;
function GetBoolValueEx(Prop: TRVItemBoolPropertyEx; RVStyle: TRVStyle): Boolean; override;
{$IFNDEF RVDONOTUSEHTML}
procedure SaveToHTML(Stream: TStream; RVData: TPersistent; ItemNo: Integer; const Text: TRVRawByteString; const Path: String; const imgSavePrefix: String; var imgSaveNo: Integer; CurrentFileColor: TColor; SaveOptions: TRVSaveOptions; UseCSS: Boolean; Bullets: TRVList); override;
{$ENDIF}
function ReadRVFLine(const s: TRVRawByteString; RVData: TPersistent; ReadType, LineNo, LineCount: Integer; var Name: TRVRawByteString; var ReadMode: TRVFReadMode; var ReadState: TRVFReadState; UTF8Strings: Boolean; var AssStyleNameUsed: Boolean): Boolean; override;
procedure SaveRVF(Stream: TStream; RVData: TPersistent; ItemNo, ParaNo: Integer; const Name: TRVRawByteString; Part: TRVMultiDrawItemPart; ForceSameAsPrev: Boolean); override;
procedure SaveRTF(Stream: TStream; const Path: String; RVData: TPersistent; ItemNo: Integer; TwipsPerPixel: Double; Level: Integer; ColorList: TRVColorList; StyleToFont, ListOverrideOffsetsList1, ListOverrideOffsetsList2: TRVIntegerList; FontTable: TRVList); override;
function GetImageHeight(RVStyle: TRVStyle): Integer; override;
function GetImageWidth(RVStyle: TRVStyle): Integer; override;
procedure MovingToUndoList(ItemNo: Integer; RVData, AContainerUndoItem: TObject); override;
function CreatePrintingDrawItem(RVData: TObject; const sad: TRVScreenAndDevice): TRVDrawLineInfo; override;
procedure UpdateAnimator(RVData: TObject); override;
{$ENDIF}
property MinHeightOnPage: Integer read FMinHeightOnPage write FMinHeightOnPage;
End;
implementation
uses RVFMisc,RichView, PtblRV, PtRVData, CRVData, CRVFData, RVUni, RVStr, CtrlImg,
RVAnimate
{$IFNDEF RVDONOTUSELISTS}
, RVMarker
{$ENDIF}
{========================= TRVImagePrintPart ==================================}
type
TRVImagePrintPart = class (TRVMultiDrawItemPart)
public
ImgTop, ImgHeight: Integer;
function GetSoftPageBreakInfo: Integer; override;
function GetImageHeight: Integer; override;
function TRVImagePrintPart.GetSoftPageBreakInfo: Integer;
Result := ImgTop;
function TRVImagePrintPart.GetImageHeight: Integer;
Result := ImgHeight;
{========================= TRVMultiImagePrintInfo =============================}
type
TRVMultiImagePrintInfo = class (TRVMultiDrawItemInfo)
private
FItem: THackRVRectItemInfo;
public
constructor Create(AItem: TRVRectItemInfo);
procedure SetSize(AWidth, AHeight: Integer); override;
function InitSplit(const Sad: TRVScreenAndDevice): Boolean; override;
function CanSplitFirst(Y: Integer; const Sad: TRVScreenAndDevice;
FirstOnPage, PageHasFootnotes, FootnotesChangeHeight: Boolean): Boolean; override;
function SplitAt(Y: Integer; const Sad: TRVScreenAndDevice;
FirstOnPage: Boolean; var FootnoteRVDataList: TList;
var MaxHeight: Integer; FootnotesChangeHeight: Boolean): Boolean; override;
function GetHTMLImageAlign(Align: TRVVAlign; SaveOptions: TRVSaveOptions;
CSSVersion: Boolean): TRVAnsiString;
case Align of
rvvaMiddle:
Result := 'middle';
rvvaAbsTop:
Result := 'abstop';
rvvaAbsBottom:
Result := 'absbottom';
rvvaAbsMiddle:
Result := 'absmiddle';
Result := '';
if (rvsoXHTML in SaveOptions) then
Result := '"'+Result+'"';
Result := ' align='+Result;
{$ENDIF}
constructor TRVMultiImagePrintInfo.Create(AItem: TRVRectItemInfo);
inherited Create;
FItem := THackRVRectItemInfo(AItem);
function TRVMultiImagePrintInfo.CanSplitFirst(Y: Integer;
const Sad: TRVScreenAndDevice; FirstOnPage, PageHasFootnotes,
Y := RV_YToScreen(Y, sad);
Result :=
(Y>0) and
FItem.GetBoolValueEx(rvbpPrintToBMP, nil) and
(FItem.FMinHeightOnPage>0) and
(Y>=FItem.FMinHeightOnPage+FItem.GetBorderHeight*2) and
((FItem.GetImageHeight(nil)-Y >= FItem.FMinHeightOnPage) or
(Y>FItem.GetImageHeight(nil)+FItem.GetBorderHeight*2));
function TRVMultiImagePrintInfo.InitSplit(const Sad: TRVScreenAndDevice): Boolean;
var part: TRVImagePrintPart;
Result := FItem.FMinHeightOnPage<>0;
if not Result then
part := TRVImagePrintPart.Create;
part.ImgTop := 0;
part.ImgHeight := FItem.GetImageHeight(nil);
part.Height := RV_YToDevice(part.ImgHeight+FItem.GetBorderHeight*2, sad);
PartsList.Add(part);
function TRVMultiImagePrintInfo.SplitAt(Y: Integer;
const Sad: TRVScreenAndDevice; FirstOnPage: Boolean;
var FootnoteRVDataList: TList; var MaxHeight: Integer;
var PrevHeight, NewHeight, PrevTop: Integer;
if FItem.FMinHeightOnPage<=0 then begin
Result := False;
if PartsList.Count=0 then
raise ERichViewError.Create(errRVPrint);
part := TRVImagePrintPart(PartsList[PartsList.Count-1]);
if (part.ImgHeight<=FItem.FMinHeightOnPage) then begin
Result := False;
PrevHeight := RV_YToScreen(Y, sad)-FItem.GetBorderHeight*2;
NewHeight := part.ImgHeight-PrevHeight;
if (NewHeight<FItem.FMinHeightOnPage) or (PrevHeight<FItem.FMinHeightOnPage) then begin
Result := False;
part.ImgHeight := PrevHeight;
PrevTop := part.ImgTop;
part.ImgTop := PrevTop+PrevHeight;
part.ImgHeight := NewHeight;
Result := True;
procedure TRVMultiImagePrintInfo.SetSize(AWidth, AHeight: Integer);
// do nothing
Function TRVChartItemInfo.GetHeight: Integer;
Begin
If (Image is TIcon)
Then TIcon(Image).Handle;
If (ImageHeight>0)
Then Result := ImageHeight
Else Result := Image.Height;
Inc(Result,Spacing*2);
End;
Function TRVChartItemInfo.GetWidth: Integer;
Begin
If (Image is TIcon)
If (ImageWidth>0)
Then Result := ImageWidth
Else Result := Image.Width;
Inc(Result, Spacing*2);
End;
Function TRVChartItemInfo.GetRVFExtraPropertyCount: Integer;
Begin
Result := inherited GetRVFExtraPropertyCount;
If (not FResizable)
Then Inc(Result);
If (ImageWidth>0)
Then Inc(Result);
If (ImageHeight>0)
Then Inc(Result);
If (MinHeightOnPage>0)
Then Inc(Result);
If (NoHTMLImageSize)
Then Inc(Result);
If (Interval>0)
Then Inc(Result);
{$IFDEF RICHVIEWCBDEF3}
If ((Image<>nil) and (Image is TBitmap) and TBitmap(Image).Transparent)
Then Begin
inc(Result,2);
If (TBitmap(Image).TransparentMode=tmFixed)
Then Inc(Result);
End;
{$ENDIF}
If (ImageFileName<>'')
Then Inc(Result);
If (Alt<>'')
Then Inc(Result);
procedure TRVChartItemInfo.SaveRVFExtraProperties(Stream: TStream);
inherited SaveRVFExtraProperties(Stream);
if not FResizable then
WriteRVFExtraIntPropertyStr(Stream, rvepResizable, ord(FResizable));
if ImageWidth>0 then
WriteRVFExtraIntPropertyStr(Stream, rvepImageWidth, ImageWidth);
if ImageHeight>0 then
WriteRVFExtraIntPropertyStr(Stream, rvepImageHeight, ImageHeight);
if MinHeightOnPage>0 then
WriteRVFExtraIntPropertyStr(Stream, rvepMinHeightOnPage, MinHeightOnPage);
if NoHTMLImageSize then
WriteRVFExtraIntPropertyStr(Stream, rvepNoHTMLImageSize, 1);
if Interval>0 then
WriteRVFExtraIntPropertyStr(Stream, rvepAnimationInterval, Interval);
if (Image<>nil) and (Image is TBitmap) and TBitmap(Image).Transparent then begin
WriteRVFExtraIntPropertyStr(Stream, rvepTransparent, 1);
WriteRVFExtraIntPropertyStr(Stream, rvepTransparentMode,
ord(TBitmap(Image).TransparentMode));
if TBitmap(Image).TransparentMode=tmFixed then
WriteRVFExtraIntPropertyStr(Stream, rvepTransparentColor,
TBitmap(Image).TransparentColor);
{$ENDIF}
if ImageFileName<>'' then
WriteRVFExtraStrPropertyStr(Stream, rvespImageFileName, ImageFileName);
if Alt<>'' then
WriteRVFExtraStrPropertyStr(Stream, rvespAlt, Alt);
Function TRVChartItemInfo.GetChartImage(NoChart:Integer):TMetaFile;
Var
Query : TUniQuery;
memStream : TMemoryStream;
Begin
Result := TMetaFile.Create;
Query := TUniQuery.Create(Nil);
Query.Connection := TInfoDB.GetInstance.Connection;
//Query.DatabaseName := DATABASE_NAME;
Query.SQL.Clear;
Query.SQL.Add('SELECT * FROM Graphiques WHERE No_Graph = '+IntToStr(NoChart));
Query.Open;
memStream := TMemoryStream.Create;
TBlobField(Query.FieldByName('Sample_Graph')).SaveToStream(memStream);
memStream.Position := 0;
Result.LoadFromStream(memStream);
memStream.Free;
Query.Close;
Query.Free;
End;
Constructor TRVChartItemInfo.CreateEx(RVData: TPersistent; NoChart:Integer; AVAlign: TRVVAlign);
Begin
inherited Create(RVData);
FNoChart := NoChart;
StyleNo := rvsChart;
Image := GetChartImage(NoChart);
VAlign := AVAlign;
FResizable := True;
End;
Constructor TRVChartItemInfo.Create(RVData: TPersistent);
Begin
FNoChart := 0;
FResizable := True;
End;
function TRVChartItemInfo.PrintToBitmap(Bkgnd: TBitmap; Preview: Boolean;
var Top, Height: Integer;
SourceImage: TGraphic;
TmpBackground: TBitmap;
{$ENDIF}
Result := True;
if Preview and (ImageCopy<>nil) then
SourceImage := ImageCopy
SourceImage := Image;
// If the source picture is increased in at least one
// dimension, resizing background image (for providing higher quality).
// Images printed on several pages (Part>=0) cannot be resized in height,
// so height is checked only if Part<0.
// If the source image is transparent, background is stretched; otherwise
// the content of bkgnd does not matter
if (bkgnd.Width<SourceImage.Width) or
((Part<0) and (bkgnd.Height<SourceImage.Height)) then begin
if SourceImage.Transparent then begin
TmpBackground := TBitmap.Create;
TmpBackground.Assign(bkgnd);
end
TmpBackground := nil;
{$ENDIF}
if bkgnd.Width<SourceImage.Width then
bkgnd.Width := SourceImage.Width;
if (Part<0) and (bkgnd.Height<SourceImage.Height) then
bkgnd.Height := SourceImage.Height;
if TmpBackground<>nil then
bkgnd.Canvas.StretchDraw(Rect(0,0,bkgnd.Width,bkgnd.Height), TmpBackground);
TmpBackground.Free;
{$ENDIF}
if (dli is TRVMultiImagePrintInfo) and (Part>=0) then begin
// Drawing the image part. Multipage images cannot be scaled in height,
// so we use SourceImage.Height
Top := -TRVImagePrintPart(TRVMultiImagePrintInfo(dli).PartsList[Part]).ImgTop;
end
else begin
// Drawing the whole image
Top := 0;
Height := bkgnd.Height;
bkgnd.Canvas.StretchDraw(Bounds(0,Top,bkgnd.Width,Height), SourceImage);
Procedure TRVChartItemInfo.Print(Canvas: TCanvas; x,y,x2: Integer; Preview, Correction: Boolean; const sad: TRVScreenAndDevice; RichView: TRVScroller; dli: TRVDrawLineInfo; Part: Integer; ColorMode: TRVColorMode; RVData: TPersistent);
var DCState: Integer;
R: TRect;
// will be called only for metafiles
DCState := SaveDC(Canvas.Handle);
R := Bounds(x+MulDiv(Spacing, sad.ppixDevice, sad.ppixScreen),
y+MulDiv(Spacing, sad.ppiyDevice, sad.ppiyScreen),
MulDiv(GetImageWidth(TCustomRichView(RichView).Style), sad.ppixDevice, sad.ppixScreen),
MulDiv(GetImageHeight(TCustomRichView(RichView).Style), sad.ppiyDevice, sad.ppiyScreen));
with R do
IntersectClipRect(Canvas.Handle, Left, Top, Right, Bottom);
Canvas.StretchDraw(r, Image);
RestoreDC(Canvas.Handle, DCState);
procedure TRVChartItemInfo.Assign(Source: TCustomRVItemInfo);
var grclass: TGraphicClass;
if Source is TRVChartItemInfo then begin
Alt := TRVChartItemInfo(Source).Alt;
FResizable := TRVChartItemInfo(Source).FResizable;
ImageFileName := TRVChartItemInfo(Source).ImageFileName;
ImageWidth := TRVChartItemInfo(Source).ImageWidth;
ImageHeight := TRVChartItemInfo(Source).ImageHeight;
NoHTMLImageSize := TRVChartItemInfo(Source).NoHTMLImageSize;
Image.Free;
ImageCopy.Free;
grclass := TGraphicClass(TRVChartItemInfo(Source).Image.ClassType);
Image := RV_CreateGraphics(grclass);
Image.Assign(TRVChartItemInfo(Source).Image);
if TRVChartItemInfo(Source).ImageCopy<>nil then begin
grclass := TGraphicClass(TRVChartItemInfo(Source).ImageCopy.ClassType);
ImageCopy := RV_CreateGraphics(grclass);
ImageCopy.Assign(TRVChartItemInfo(Source).ImageCopy);
end
ImageCopy := nil;
inherited Assign(Source);
procedure TRVChartItemInfo.TransferProperties(Source: TCustomRVItemInfo;
if (FAnimator=nil) and (Source is TRVChartItemInfo) then begin
FAnimator := TRVChartItemInfo(Source).FAnimator;
TRVChartItemInfo(Source).FAnimator := nil;
if FAnimator<>nil then
TRVAnimator(FAnimator).Update(nil, Self);
UpdateAnimator(RVData);
{$ENDIF}
function TRVChartItemInfo.SetExtraIntProperty(Prop: TRVExtraItemProperty;
Result := False;
case Prop of
rvepResizable:
FResizable := Value<>0;
Result := True;
rvepImageWidth:
ImageWidth := Value;
Result := True;
rvepImageHeight:
ImageHeight := Value;
Result := True;
rvepMinHeightOnPage:
MinHeightOnPage := Value;
Result := True;
rvepNoHTMLImageSize:
NoHTMLImageSize := Value<>0;
Result := True;
rvepAnimationInterval:
Interval := Value;
Result := True;
rvepTransparent:
if (Image<>nil) and (Image is TBitmap) then begin
TBitmap(Image).Transparent := Value<>0;
Result := True;
rvepTransparentMode:
TBitmap(Image).TransparentMode := TTransparentMode(Value);
Result := True;
rvepTransparentColor:
TBitmap(Image).TransparentColor := TColor(Value);
Result := True;
{$ENDIF}
Result := inherited SetExtraIntProperty(Prop, Value);
function TRVChartItemInfo.GetExtraIntProperty(Prop: TRVExtraItemProperty;
Result := False;
case Prop of
rvepResizable:
Value := ord(FResizable);
Result := True;
rvepImageWidth:
Value := ImageWidth;
Result := True;
rvepImageHeight:
Value := ImageHeight;
Result := True;
Value := MinHeightOnPage;
Result := True;
Value := ord(NoHTMLImageSize);
Result := True;
Value := Interval;
Result := True;
rvepTransparent:
Value := ord(TBitmap(Image).Transparent);
Result := True;
Value := ord(TBitmap(Image).TransparentMode);
Result := True;
Value := Integer(TBitmap(Image).TransparentColor);
Result := True;
{$ENDIF}
Result := inherited GetExtraIntProperty(Prop, Value);
function TRVChartItemInfo.SetExtraStrProperty(
case Prop of
rvespImageFileName:
ImageFileName := Value;
Result := True;
rvespAlt:
Alt := Value;
Result := True;
Result := inherited SetExtraStrProperty(Prop, Value);
function TRVChartItemInfo.GetExtraStrProperty(
case Prop of
rvespImageFileName:
Value := ImageFileName;
Result := True;
rvespAlt:
Value := Alt;
Result := True;
Result := inherited GetExtraStrProperty(Prop, Value);
procedure TRVChartItemInfo.UpdatePaletteInfo(PaletteAction: TRVPaletteAction;
Palette: HPALETTE;
if not (PaletteAction in [rvpaCreateCopies,rvpaCreateCopiesEx]) or ForceRecreateCopy or
(Palette=0) then begin
ImageCopy.Free;
ImageCopy := nil;
// if ImageCopy=nil then
// ImageCopy := TBitmap.Create;
// ImageCopy.Width := Image.Width;
// ImageCopy.Height := Image.Height;
// TBitmap(ImageCopy).Canvas.Draw(0,0,Image);
case PaletteAction of
{*} rvpaAssignPalette:
if LogPalette<>nil then
RV_SetPaletteToPicture(Image,LogPalette);
{*} rvpaCreateCopies,rvpaCreateCopiesEx:
if (LogPalette<>nil) and (ImageCopy=nil) then begin
{$IFNDEF RVDONOTUSEJPEGIMAGE}
if (PaletteAction=rvpaCreateCopiesEx) and
(Image is TJpegImage) then
{$ENDIF}
ImageCopy := RV_CreateGraphics(TGraphicClass(Image.ClassType));
ImageCopy.Assign(Image);
RV_SetPaletteToPicture(ImageCopy,LogPalette);
if ImageCopy is TBitmap then
TBitmap(ImageCopy).IgnorePalette := True;
function TRVChartItemInfo.GetMinWidth(sad: PRVScreenAndDevice; Canvas: TCanvas;
if Image is TIcon then
if (ImageWidth>0) then
inc(Result, Spacing*2);
if sad<>nil then
Result := MulDiv(Result, sad.ppixDevice, sad.ppixScreen);
destructor TRVChartItemInfo.Destroy;
Image.Free;
ImageCopy.Free;
FAnimator.Free;
{$ENDIF}
inherited Destroy;
function TRVChartItemInfo.AsImage: TGraphic;
Result := Image;
procedure TRVChartItemInfo.Paint(x, y: Integer; Canvas: TCanvas;
var w,h: Integer;
SelColor: TColor;
procedure DrawBmp;
if (ImageWidth=0) and (ImageHeight=0) then
BitBlt(Canvas.Handle, x, y,
ImageCopy.Width, ImageCopy.Height,
TBitmap(ImageCopy).Canvas.Handle, 0, 0, SRCCOPY)
StretchBlt(Canvas.Handle, x, y, w, h,
ImageCopy.Width, ImageCopy.Height, SRCCOPY);
procedure DrawImage(Image: TGraphic);
DCState := 0;
if (ImageWidth=0) and (ImageHeight=0) then begin
if Image is TMetafile then begin
IntersectClipRect(Canvas.Handle, x, y, x+Image.Width, y+Image.Height);
Canvas.Draw(x, y, Image);
except
end
else begin
IntersectClipRect(Canvas.Handle, x, y, x+w, y+h);
Canvas.StretchDraw(Bounds(x, y, w, h), Image);
except
if DCState<>0 then
if not RVNT then
Canvas.Refresh;
w := GetImageWidth(Style);
h := GetImageHeight(Style);
inc(x, Spacing); inc(y, Spacing);
TRVAnimator(FAnimator).Draw(x,y,Canvas, False)
{$ENDIF}
if ImageCopy<>nil then
DrawBmp
DrawImage(ImageCopy)
DrawImage(Image);
if (rvidsSelected in State) then begin
if rvidsControlFocused in State then
SelColor := Style.SelColor
SelColor := Style.InactiveSelColor;
{$IFDEF RVSHADESELECTION}
ShadeRectangle(Canvas, Bounds(x,y,w,h), SelColor);
{$ELSE}
Canvas.Pen.Color := SelColor;
Canvas.Brush.Style := bsClear;
if Canvas.Pen.Color<>clNone then begin
Canvas.Pen.Style := psSolid;
Canvas.Pen.Width := 1;
Canvas.Rectangle(x-Spacing,y-Spacing, x+w+Spacing, y+h+Spacing);
{$ENDIF}
if (rvidsCurrent in State) and (Style.CurrentItemColor<>clNone) then begin
Canvas.Pen.Color := Style.CurrentItemColor;
Canvas.Rectangle(x-Spacing-1,y-Spacing-1, x+w+Spacing+1, y+h+Spacing+1);
function TRVChartItemInfo.GetBoolValue(Prop: TRVItemBoolProperty): Boolean;
case Prop of
rvbpResizable:
Result := (Image<>nil) and not (Image is TIcon) and FResizable;
rvbpValid:
Result := Image<>nil;
rvbpResizeHandlesOutside:
Result := FAnimator<>nil;
{$ELSE}
Result := False;
{$ENDIF}
rvbpDrawingChangesFont:
Result := True;
Result := inherited GetBoolValue(Prop);
function TRVChartItemInfo.GetBoolValueEx(Prop: TRVItemBoolPropertyEx; RVStyle: TRVStyle): Boolean;
case Prop of
rvbpDisplayActiveState:
Result := True;
rvbpPrintToBMP:
Result := not (Image is TMetafile);
Result := inherited GetBoolValueEx(Prop, RVStyle);
procedure TRVChartItemInfo.SaveToHTML(Stream: TStream; RVData: TPersistent;
function GetExtraIMGStr: TRVAnsiString;
var s: TRVAnsiString;
RVStyle: TRVStyle;
Result := '';
if rvsoNoHypertextImageBorders in SaveOptions then
RV_AddStrA(Result, {$IFDEF RVUNICODESTR}AnsiStrings.{$ENDIF}
Format('border=%s',[RV_HTMLGetIntAttrVal(0, SaveOptions)]));
RVStyle := TCustomRVData(RVData).GetRVStyle;
if ((rvsoImageSizes in SaveOptions) and not NoHTMLImageSize) or
(ImageWidth>0) or (ImageHeight>0) then
Format('width=%s height=%s', [
RV_HTMLGetIntAttrVal(GetImageWidth(RVStyle), SaveOptions),
RV_HTMLGetIntAttrVal(GetImageHeight(RVStyle), SaveOptions)]));
if (Alt<>'') or UseCSS then begin
s := StringToHTMLString(Alt, SaveOptions, RVStyle);
RV_AddStrA(Result, 'alt="'+s+'"');
if Spacing>0 then
Format('hspace=%s vspace=%s', [
RV_HTMLGetIntAttrVal(Spacing, SaveOptions),
RV_HTMLGetIntAttrVal(Spacing, SaveOptions)]));
{$IFNDEF RVDONOTUSEITEMHINTS}
if Hint<>'' then begin
s := StringToHTMLString(RV_GetHintStr(rvsfHTML, Hint), SaveOptions, RVStyle);
RV_AddStrA(Result, s);
{$ENDIF}
if UseCSS then begin
s := GetVShiftCSS(RVStyle);
if s<>'' then
Format('style="%s"',[s]));
if Result<>'' then
Result := ' '+Result+' '
Result := ' ';
var Location: String;
DoDefault: Boolean;
if (ImageFileName<>'') and (rvsoUseItemImageFileNames in SaveOptions) then
TCustomRVData(RVData).HTMLSaveImage(TCustomRVData(RVData), ItemNo, Path, CurrentFileColor, Location, DoDefault);
if DoDefault then
Location := TCustomRVData(RVData).DoSavePicture(rvsfHTML, imgSavePrefix, Path,
imgSaveNo, rvsoOverrideImages in SaveOptions, CurrentFileColor, Image);
if Location<>'' then
RVWrite(Stream, {$IFDEF RVUNICODESTR}AnsiStrings.{$ENDIF}Format('<img%s%ssrc="%s"%s>',
[GetHTMLImageAlign(VAlign, SaveOptions, UseCSS), GetExtraIMGStr,
StringToHTMLString(RV_GetHTMLPath(Location), SaveOptions, TCustomRVData(RVData).GetRVStyle),
RV_HTMLGetEndingSlash(SaveOptions)]));
{$ENDIF}
Function TRVChartItemInfo.ReadRVFLine(const s: TRVRawByteString; RVData: TPersistent; ReadType, LineNo, LineCount: Integer; var Name: TRVRawByteString; var ReadMode: TRVFReadMode; var ReadState: TRVFReadState; UTF8Strings: Boolean; var AssStyleNameUsed: Boolean): Boolean;
Var
ifn: String;
GraphicClassName: String;
Begin
Result := True;
If (LineNo = 1)
Then Begin
FNoChart := StrToInt(s);
Image := GetChartImage(FNoChart);
End;
SetExtraPropertyFromRVFStr(s, UTF8Strings);
function TRVChartItemInfo.ReadRVFLine(const s: TRVRawByteString; RVData: TPersistent;
var grcls : TGraphicClass;
ifn: String;
Result := True;
case ReadType of
1: // ask user
case LineNo of
0:
Image := TCustomRVData(RVData).RVFPictureNeeded(
{$IFDEF RVUNICODESTR}String(TRVAnsiString(s)),{$ELSE}s,{$ENDIF}
Tag);
ifn := ImageFileName;
if (ifn<>ImageFileName) and (ImageFileName<>'') and (Image=nil) then
Image := TCustomRVData(RVData).RVFPictureNeeded(ImageFileName, Tag);
else // load picture from file
if LineNo=0 then
else if LineNo=1 then begin
GraphicClassName := String(s);
{$ELSE}
GraphicClassName := s; // workaround for Delphi 3-6 bug
{$ENDIF}
grcls := TGraphicClass(GetClass(GraphicClassName));
if grcls=nil then begin
TCustomRVData(RVData).RVFWarnings :=
TCustomRVData(RVData).RVFWarnings + [rvfwUnknownPicFmt];
if not (rvfoIgnoreUnknownPicFmt in TCustomRVData(RVData).RVFOptions) then
Result := False;
end
else begin
Image := RV_CreateGraphics(grcls);
end
else if LineNo=LineCount-1 then begin
if Image<>nil then begin
if ReadType=2 then
RVFLoadPictureBinary(s, Image)
Result := RVFLoadPicture(s, Image);
{$IFNDEF RVDONOTCORRECTWMFSCALE}
if (Image is TMetafile)
{$IFNDEF RVCORRECTWMFSCALE2} and not TMetafile(Image).Enhanced{$ENDIF} and
(TMetafile(Image).Inch=0) then
TMetafile(Image).Inch := 1440;
{$ENDIF}
except
Image.Free;
Image := RV_CreateGraphics(TGraphicClass(TCustomRVData(RVData).
GetRVStyle.InvalidPicture.Graphic.ClassType));
Image.Assign(TCustomRVData(RVData).GetRVStyle.InvalidPicture.Graphic);
TCustomRVData(RVData).RVFWarnings+[rvfwInvalidPicture];
ReadState := rstSkip;
end
if (ReadType=2) and (LineNo=LineCount-2) then
ReadMode := rmBeforeBinary;
procedure TRVChartItemInfo.SaveRVF(Stream: TStream;
var SaveType, LineCount, Pos: Integer;
InvalidGraphic: TGraphic;
if rvfoSavePicturesBody in TCustomRVData(RVData).RVFOptions then begin
if rvfoSaveBinary in TCustomRVData(RVData).RVFOptions then
SaveType := 2 // save binary
SaveType := 0; // save hex dump
LineCount := 3+GetRVFExtraPropertyCount;
end
else begin
SaveType := 1; // do not save
LineCount := 1+GetRVFExtraPropertyCount;
RVFWriteLine(Stream,
{$IFDEF RVUNICODESTR}AnsiStrings.{$ENDIF}Format('%d %d %s %d %d %s %s',
[StyleNo, LineCount,
RVFItemSavePara(ParaNo, TCustomRVData(RVData), ForceSameAsPrev),
Byte(RVFGetItemOptions(ItemOptions,ForceSameAsPrev)) and RVItemOptionsMask,
SaveType,
RVFSaveTag(rvoTagsArePChars in TCustomRVData(RVData).Options, Tag),
SaveRVFHeaderTail(RVData)]));
RVFWriteLine(Stream, Name);
if SaveType<>1 then begin
Pos := Stream.Position;
RVFWriteLine(Stream, TRVAnsiString(Image.ClassName));
RVFSavePictureBinary(Stream, Image)
RVFWriteLine(Stream, RVFSavePicture(Image));
except
if Stream.Size=Stream.Position then
Stream.Size := Pos;
Stream.Position := Pos;
InvalidGraphic := TCustomRVData(RVData).GetRVStyle.InvalidPicture.Graphic;
RVFWriteLine(Stream, TRVAnsiString(InvalidGraphic.ClassName));
RVFSavePictureBinary(Stream, InvalidGraphic)
RVFWriteLine(Stream, RVFSavePicture(InvalidGraphic));
end
Procedure TRVChartItemInfo.SaveRVF(Stream: TStream; RVData: TPersistent; ItemNo, ParaNo: Integer; const Name: TRVRawByteString; Part: TRVMultiDrawItemPart; ForceSameAsPrev: Boolean);
Begin
SaveType := 0;
LineCount := 2+GetRVFExtraPropertyCount;
RVFWriteLine(Stream,{$IFDEF RVUNICODESTR}AnsiStrings.{$ENDIF}Format('%d %d %s %d %d %s %s', [StyleNo, LineCount, RVFItemSavePara(ParaNo, TCustomRVData(RVData), ForceSameAsPrev), Byte(RVFGetItemOptions(ItemOptions,ForceSameAsPrev)) and RVItemOptionsMask, SaveType, RVFSaveTag(rvoTagsArePChars in TCustomRVData(RVData).Options, Tag), SaveRVFHeaderTail(RVData)]));
RVFWriteLine(Stream,Format('%d',[FNoChart]));
procedure TRVChartItemInfo.SaveRTF(Stream: TStream; const Path: String;
RVSaveImageToRTF(Stream, TwipsPerPixel, Image, ImageWidth, ImageHeight,
TCustomRVData(RVData).RTFOptions,
{$IFNDEF RVDONOTUSEANIMATION}FAnimator{$ELSE}nil{$ENDIF});
function TRVChartItemInfo.GetImageHeight(RVStyle: TRVStyle): Integer;
if (ImageHeight>0) then
function TRVChartItemInfo.GetImageWidth(RVStyle: TRVStyle): Integer;
procedure TRVChartItemInfo.MovingToUndoList(ItemNo: Integer; RVData, AContainerUndoItem: TObject);
ImageCopy.Free;
ImageCopy := nil;
if FAnimator<>nil then begin
FAnimator.Free;
FAnimator := nil;
{$ENDIF}
inherited MovingToUndoList(ItemNo, RVData, AContainerUndoItem);
function TRVChartItemInfo.CreatePrintingDrawItem(RVData: TObject;
if not GetBoolValueEx(rvbpPrintToBMP, nil) or (MinHeightOnPage=0) or
((ImageHeight>0) and (ImageHeight<>Image.Height)) then begin
Result := TRVDrawLineInfo.Create;
Result := TRVMultiImagePrintInfo.Create(Self);
Result.Width := RV_XToDevice(GetWidth, sad);
Result.Height := RV_YToDevice(GetHeight, sad);
procedure TRVChartItemInfo.UpdateAnimator(RVData: TObject);
if RVData is TCustomRVFormattedData then begin
if not TCustomRVFormattedData(RVData).AllowAnimation then begin
FAnimator.Free;
FAnimator := nil;
end
RV_MakeAnimator(Self, TCustomRVFormattedData(RVData), TRVAnimator(FAnimator));
end.
I did try SRV.RichViewEdit.LoadRVF and then SRV.SetRVMargins(True); and i got no redraw, so im still using the Format procedure;Sergey Tkachenko wrote:As for the first problem, I suggest
1) to update to SRV 3.1.1, I remember we fixed a problem with SRV.LoadRVF in that version.
2) if you use SRV.RichViewEdit.LoadRVF, then call SRV.SetRVMargins instead of Format
Since i dont know that is going on, hehehe, ill update it right away.
Since I cannot compile this unit, it's hard to debug it.
Where is RegisterRichViewItemClass called? You said that you used the same constant name (rvsChart) for 2 different constants?
When loading from RVF, Create is called, not CreateEx.
Add a breakpoint in CreateRichViewItem function (RVItem.pas), in the cycle "for i := 0 to RichViewItemClassesList.Count-1 do". This cycle is executed when loading custom items from RVF. Can this cycle create an object for your item class?
Yes, i know, i use UniDac in it and access my DB to get my MetaFile image to draw it.Since I cannot compile this unit, it's hard to debug it.
Its called in my main,pas its my mainform for my application. Since i can add it correctly, i presume its called correctly.Where is RegisterRichViewItemClass called? You said that you used the same constant name (rvsChart) for 2 different constants?
rvsChart is used for only 1 kind of component. i have an other constant with value -14 for an other custom component.
Any of them are beeing called.When loading from RVF, Create is called, not CreateEx.
Ok, ill check the function that create custom item.Add a breakpoint in CreateRichViewItem function (RVItem.pas), in the cycle "for i := 0 to RichViewItemClassesList.Count-1 do". This cycle is executed when loading custom items from RVF. Can this cycle create an object for your item class?
I did some other testing and it seems it stop reading the file when it encounter my custom item. Can it be a save issue ? Because i did copy the code from your RVItem and manipulate it to work as i would like, but maybe i dont save the information correctly (from 2.4 to 3.1 maybe there was some changes)
What i did was simple, i add some random text, add my rvsChart, add some text then saved. When i load it back, all i got is my first line of text. So it seem the load function get broken somewhere and im pretty its from my rvschart.
Begin
SaveType := 0;
Var
ifn: String;
Begin
ShowMessage('A');
Result := True;
If (LineNo = 1)
Then Begin
End;
thanks again
GoToXY
I really dont understand what is going on. I did check out the function CreateRichViewItem in RVItem.pas and therically, everything should go as perfect, but it doesnt. what is really wierd is that:
when looping
I did add
the result is just fine "TRVChartItemInfo -13"
then, your code create the TRVItem:
[code
Result := TRichViewItemTypeInfo(RichViewItemClassesList).ItemClass.Create(RVData);
Result.StyleNo := StyleNo;
[/code]
then ive add : ShowMessage(Result.ClassName);
and it say TRVChartItemInfo too. So how come its not working ? well i did add some ShowMessage in TRVChartItemInfo .Create AND TRVChartItemInfo .CreateEX just in case and Surprise!!! nothing. So im wondering how could my class be created without going through my create ?!? I'm really confused now. Usually, if the Register didnt worked, i should get "can't find TRVChartItemInfo class" as an exception but i got nothing. Hope this can bring some light to my nightmare heheheh
thanks again
when looping
if TRichViewItemTypeInfo(RichViewItemClassesList[i]).StyleNo=StyleNo then begin
ShowMessage(TRichViewItemTypeInfo(RichViewItemClassesList[i]).ItemClass.ClassName+#13+IntToStr(StyleNo));
[code
[/code]
thanks again
