SRV and TabSheet
gotoxy
SRV and TabSheet
Post by gotoxy »
Is it only me or others are getting range check error when dropping a SRV into a TTabSheet of a TPageControl.
How to reproduce:
1. Create a new Application VCL
2. Drop a TPageControl
3. Add a Page
5. Drop SRV into the tabsheet
6. Set Align to alClient of the SRV
7. Run and get the error
How i did come to that, is im getting drawing issue in my software where i dock the SRV in real time to a TPageControl. the 2 Scrollbar are redrawn in black and i have to pass my mouse over to get it refreshed. Initially i use TAdvPageControl so i though i could have been a parent redraw error, but i cant get my test to run because of the range check error.
Screen shot of the issue with painting:
Thanks for your time
Can you create a simple project to reproduce, preferable without thirdparty controls?
gotoxy
Post by gotoxy »
How to reproduce:
3. Add a Page
There is no third party controls.
and if your request about the application was about the scrollbar refresh issue, well
Thanks again to take your time
GoToXY
Meanwhile, turn off range checking in the project options.
gotoxy
Post by gotoxy »
ok thx
