CRVData error
gbg
CRVData error
Post by gbg »
i dont use CRVData in my program
but when i close myprogram i get error and delphi want debug CRVData.pas
but i use CRVFData for addnlwtag
:roll:
gbg
Post by gbg »
if i don`t use addnlwtag program terminate normaly
Please post your code, how you call AddNLWTag
The most probable reason for this error:
You included rvoTagsArePChars in RichView.Options, so RichView thinks that tags are pointers to strings allocated using StrNew function.
But when you call AddNLWTag, you pass some integer value instead of pointer to the string as a tag.
Am I right?
gbg
Post by gbg »
Mytext1..5 is wide string;
ReciveText.AddNLWTag('Mytext1',0,0,0);
ReciveText.AddNLWTag('Mytext2',0,0,0);
ReciveText.AddNLWTag('Mytext3',3,-1,100); //
ReciveText.AddNLWTag('Mytext4',0,-1,0);
ReciveText.AddNLWTag('Mytext5',3,-1,101); //
ReciveText.AddNLWTag('Mytext6',0,-1,0);
ReciveText.Format;
procedure ReciveTextJump is :
TCustomRichView(Sender).GetJumpPointLocation(id, RVData, ItemNo);
ReciveText.GetJumpPointLocation(id, RVData, ItemNo);
Tag := RVData.GetItemTag(ItemNo);
if Tag>0 then
if Tag=100 then
s:='\VAC';
if Tag=101 then
s:='\VEDE';
gbg
Post by gbg »
Sergey Tkachenko wrote:The most probable reason for this error:
Am I right?
this forum dont have thanks button
i set rvoTagsArePChars to false and problem solve
