I have a problem to create html file.
I have downloaded the demo about how to save html format.
I also download the demo about how to insert table into TRichViewEdit.
When I create a table from template and save it to html, this process can
still work properly.
The problem raised when I try to copy table from excel to TRichViewEdit
and save it to html. It seems that can not work correctly. I can see the
data in the html file, but I can not see the border. As I said above, if I
create the table from the template and provide it with some information in
the cell and export it to html, I can see the data and the border, but not
for table which paste from excel.
Does any direction or help to achieve it?
Any help or direction is greatly appreciated.
Thank in advance.
regards,
Eko Indriyawan
Can not create html correctly
