Hi there,
I've implemented a mail merge solution where the user stores the model text (RVF) in the database. The text is stored as something like:
Dear <<Name>>,
You reside at <<district>>!
It's all working, but some users will use the term "district", others will use "village", an so on...
I'm looking for the simplest way to replace the occurrences of a given word in all the model text records stored in the database.
Any idea?
Regards.
Update many records
Mail merge demos: http://www.trichview.com/forums/viewtopic.php?t=8
I think you specifically need http://www.trichview.com/support/files/ ... e-text.zip
