How to set table.SetCellVAlign for selected cells and at cur
w2m
Post by w2m »
1. How to set table.SetCellVAlign for selected cells and at the caret position?
procedure TFormMain.TableCellVAlignMiddle1Click( Sender: TObject );
  Item: TCustomRVItemInfo;
  Table: TRVTableItemInfo;
  RichViewEdit: TCustomRichViewEdit;
  ItemNo: integer;
  r, c: integer;
  tr, lc: integer;
  sc, sr: integer;
  RVData: TCustomRVFormattedData;
  if Assigned( AdvOfficePager1.ActivePage ) then
    cxTRichViewEdit := TcxTRichViewEdit( AdvOfficePager1.ActivePage.Controls[ 0 ] );
    if not cxTRichViewEdit.InnerEditor.CanChange or not cxTRichViewEdit.InnerEditor.GetCurrentItemEx( TRVTableItemInfo,
      RichViewEdit, Item ) then
    Table := TRVTableItemInfo( Item );
    ItemNo := RichViewEdit.GetItemNo( Table );
    for r := 0 to table.Rows.Count - 1 do
      for c := 0 to table.Rows[ r ].Count - 1 do
        if table.Cells[ r, c ] <> nil then
          if table.IsCellSelected( r, c ) then
            with table.Cells[ r, c ].VisibleBorders do
              table.SetCellVAlign( rvcMiddle, r, c );
          end
          // not selected so SetCellVAlign at the caret position?
2. How to select only the single cell at the caret position?
3. Is there a way to select one cell? I can select 2 cells but not one?
var Data: Integer;
RichViewEdit.BeginItemModify(ItemNo, Data);
if table.GetEditedCell(r,c)<>nil then
  // the caret is in a table cell
else begin
  // applying to selected cells
  RichViewEdit.BeginUndoGroup(rvutModifyItem);
  RichViewEdit.SetUndoGroupMode(True);
      if (table.Cells[r,c ]<>nil) and table.IsCellSelected( r, c ) then
  RichViewEdit.SetUndoGroupMode(False);
RichViewEdit.EndItemModify(ItemNo, Data);
RichViewEdit.Change;
User cannot select one cell with the mouse of the keyboard.
However, you can select it using table.Select method
(in RichViewActions, TrvActionTableSelectCell calls this method to select one cell)
w2m
Post by w2m »
Your code almost worked but I had to modify it to work without an exception in the line TRichViewEdit.InnerEditor.BeginItemModify( ItemNo, Data );
  ItemNo: integer;
  r, c: integer;
  Data: Integer;
    cxTRichViewEdit.InnerEditor.BeginItemModify( ItemNo, Data );
    if table.GetEditedCell( r, c ) <> nil then
      cxTRichViewEdit.InnerEditor.BeginUndoGroup( rvutModifyItem );
      cxTRichViewEdit.InnerEditor.SetUndoGroupMode( True );
          if ( table.Cells[ r, c ] <> nil ) and table.IsCellSelected( r, c ) then
      cxTRichViewEdit.InnerEditor.SetUndoGroupMode( False );
    cxTRichViewEdit.InnerEditor.EndItemModify( ItemNo, Data );
    cxTRichViewEdit.InnerEditor.Change;
This is what I did to make Select cell work:
procedure TFormMain.SelectCell1Click( Sender: TObject );
  ItemNo: integer;
  r, c: integer;
  Data: Integer;
      table.Select( r, c, 0, 0 );
Do you think this is correct?
Thanks for your help.
Bill
BeginItemModify, EndItemModify and Change must be called for TRichViewEdit containing the table in its items.
It's not necessary the root editor (i.e. cxTRichViewEdit.InnerEditor), it is the editor returned by GetCurrentItemEx.
So my original code was correct.
As for your second code sample, it is correct (with the exception of using cxTRichViewEdit.InnerEditor instead of RichViewEdit for BeginItemModify/EndItemModify).
Actually BeginItemModify and EndItemModify are not necessary for selection, because selection is not a modification. It's enough to call RichViewEdit.Invalidate after table.Select.
