clear content manually without actions
JohnMirror
Post by JohnMirror »
How can I clear manually the content of ScaleRichView before loading another file..?
Is ScaleRichView.Clear good...?
Thank you.
Yes, call TSRichViewEdit.Clear.
JohnMirror
Ok, thanks.
After srv.Clear, call srv.Format.
JohnMirror
Ok.
If, between Clear and Format, sometimes I load a rtf, Format will use srv.onProgress too?
Currently, OnProgress is called only while loading RTF (if RTF is not too small). In future, it will be called while loading other formats too.
May be Format will call it too, but not soon.
JohnMirror
Ok.
Maybe you'll implement for saving rtf too. On larger ones I wait 10..20 sec...
