List index out of bounds calling rvPrint.format
motoplex
Post by motoplex »
Dear Mr,
I'm using a registered Trichview v1.9 with D7.
In my application I encounter trouble when adding headers and/or footers
to RVprint.
Using : richview1 with rvStyle1
richeditfooter with rvStyleFooter
richeditheader with rvStyleHeader
rvPrint1
rvPrintPreview with rvPrint1
related parts of code:
RichviewEditHeader.Clear;
//RichviewEditHeader.DeleteUnusedStyles(True,True,True);
RichView1.RTFReadProperties.SetHeader(RichViewEditHeader.RVData);
RichviewEditHeader.LoadRTF(path1);
RichviewEditHeader.Format;
RichviewEditFooter.Clear;
//RichviewEditFooter.DeleteUnusedStyles(True,True,True);
RichView1.RTFReadProperties.SetHeader(RichViewEditFooter.RVData);
RichviewEditFooter.LoadRTF(path2);
RichviewEditFooter.Format;
Richview1.Clear;
//RichView1.DeleteUnusedStyles(True,True,True);
RichView1.Format;  // uit voorbeeld headers-footers demo
Richview1.BackGroundStyle:=bsTiled; //bsStretched,bsTiledAndScrolled;
Richview1.BackGroundBitmap:=BGbitmap1;
Richview1.Style:=RVStyle1;
Richview1.Clear;
//RichView1.DeleteUnusedStyles(True,True,True);  // uit voorbeeld
RichView1.Format;
Richview1.AddPicture(MFile2resized);
Richview1.Format;
Richview1.format;
rvPrint1.StartAt := MaxHeight;
rvPrint1.AssignSource(Richview1);
rvPrint1.SetHeader(RichViewEditHeader.RVData);
rvPrint1.SetFooter(RichViewEditFooter.RVData);
All this executes (well?) and does not cause problems if I leave out the
commands rvPrint1.SetHeader() and rvPrint.SetFooter().
With these commands (wanting headers and footers) the
following line causes a list index out of bounds :
NofPages := RVPrint1.FormatPages(rvdoAll);
I've traced the fault to procedure :
procedure TCustomMainPtblRVData.FormatNextPage(var i, StartAt, StartY, Y: Integer; var Splitting: Boolean; MaxHeight: Integer);
pi := GetRVStyle.ParaStyles[GetItemPara(DrawItems[nextnewline-1].ItemNo)];
above line is called with nextnewline=0 ; why ?
Can you give me a Hint for the probable cause ?
regards,
Sander
motoplex
rvPrint.Format out of bounds error
Post by motoplex »
Dear Sir,
Solved the problem ...... excact cause (not yet) known but my
presentation of the order of execution of listed code lines was
not as presented !
p.s. I should have checked this earlyer instead of 'assuming' ...
Regards,
Sander
Probably RVStyles were not assigned to RichViews representing header and footer.
