GetAllText WordWrap Returns?
ThYpHoOn
Post by ThYpHoOn »
Hi folks,
i've a problem with the GetAllText function if i want only the plain-text of a document. If i'm tipping a long text with the property wordwrap = true then ther will be carriage return(line feeds)'s shown but if i'm getting the text with GetAllText they won't be exportet. Is there a clue to get them?
Greetings, ThY
All TRichView text exporting functions ignore line wrapping, the inserts #13#10 only in places of paragraph breaks.
I'll post a function with line wrapping tomorrow.
ThYpHoOn
Post by ThYpHoOn »
Sergey Tkachenko wrote:All TRichView text exporting functions ignore line wrapping, the inserts #13#10 only in places of paragraph breaks.
Thanks for the quick answer and for the solution, i'm waiting :)
Gz, ThYpHoOn
This function uses undocumented methods.
1) Include RV_Defs.inc in your unit, it contains RVUNICODESTR define:
{$I RV_Defs.inc}
Include in uses: CRVFData, DLines, RVTable, RVItem.
2) A helper function
// Converting text from internal representation to String
function ConvertItemTextToString(const ItemText: TRVRawByteString;
  UnicodeItem: Boolean; CodePage: Cardinal): String;
  {$IFDEF RVUNICODESTR} // <-- declared in RV_Defs.inc
  // Delphi 2009+: String is Unicode
  if UnicodeItem then
    Result := RVU_RawUnicodeToWideString(ItemText)
      RVU_AnsiToUnicode(CodePage, ItemText));
  {$ELSE}
  // Delphi 4-2007: String is ANSI
  if UnicodeItem then
    Result := RVU_UnicodeToAnsi(CodePage, ItemText)
    Result := ItemText;
  {$ENDIF}
3) Main function
function GetFormattedText(RVData: TCustomRVFormattedData): String;
var i, r, c, ItemNo, StyleNo: Integer;
    table: TRVTableItemInfo;
  Result := '';
  for i := 0 to RVData.DrawItems.Count-1 do begin
    if (i>0) and RVData.DrawItems[i].FromNewLine then
      Result := Result+#13#10;
    ItemNo := RVData.DrawItems[i].ItemNo;
    StyleNo := RVData.GetItemStyle(ItemNo);
    if StyleNo=rvsTab then
      Result := Result+#9
    else if StyleNo=rvsTable then begin
      table := TRVTableItemInfo(RVData.GetItem(ItemNo));
        for c := 0 to table.ColCount-1 do begin
          if table.Cells[r,c]<>nil then
            Result := Result + GetFormattedText(TCustomRVFormattedData(table.Cells[r,c].GetRVData));
          if not ((r=table.RowCount-1) and (c=table.ColCount-1)) then
      end
    else if StyleNo>=0 then
      Result := Result+ConvertItemTextToString(
        RVData.DrawItems.GetString(i, RVData.Items),
        RVData.GetRVStyle.TextStyles[StyleNo].Unicode,
        RVData.GetItemCodePage(ItemNo));
How to use:
  Memo1.Lines.Text := GetFormattedText(RichViewEdit1.RVData)
ThYpHoOn
Post by ThYpHoOn »
Thanks alot, this works fine :)
Gz, ThYpHoOn
ThYpHoOn
Post by ThYpHoOn »
A little note on this, GetAllText has converted the text (if it was RichEdit) to plaintext, but the new function did not do this. Any idea for this?
This isn't so bad, i could check the text if its RichText... but if there is a easy tweak for this i'm glad to hear from it.
Gz, ThYpHoOn
Sorry, I do not understand, what do you mean by "GetAllText has converted the text (if it was RichEdit) to plaintext"
ThYpHoOn
Post by ThYpHoOn »
The result of GetAllText is completely unformatted and non-rtf, but the function "GetFormattedText" give's the RTF-Formatted text as a result.
Gz, ThYpHoOn
GetFormattedText, like GetAllText, returns a plain text.
The only differences
- GetFormattedText adds more line break characters in places of line wrapping;
- GetFormattedText does not include text representation of non-text items (except for tabs and tables)
ThYpHoOn
Post by ThYpHoOn »
Sergey Tkachenko wrote:?
Uh, sorry there was a mistake/bug in my code.
