List Index out of bounds Error
bswift
Post by bswift »
Hello all,
I have a routine that I have been using to format different strings as I added then to a TRichViewEdit. Up until I upgraded my Richview stuff it worked perfect and as a matter of fact, it still does, but only when run outside of the IDE. Here is the code and the error is noted:
procedure TMain.ChangeFonts(TheFont,TheSize,TheColor,TheBColor,B,I,U,P:string);
   with RVS.TextStyles.Add do
     FontName := TheFont;
     Size := strtoint(TheSize);
     Color:= stringtocolor(TheColor);
     BackColor:=stringtocolor(TheBColor);
     if B='1' then
     Style := Style+[fsbold] else
     Style := Style-[fsbold];
     if I='1' then
     Style := Style+[fsitalic] else
     Style := Style-[fsitalic];
     if U='1' then
     Style := Style+[fsunderline] else
     Style := Style-[fsunderline];
     RVE.ApplyTextStyle(RVS.TextStyles.Count-1);  <-----Exception here EList Error "List Index out of bounds (-1)
     ts:=RVS.TextStyles.Count-1;
     with RVS.ParaStyles.Add do
     if P='0' then Alignment:=rvaLeft;
     if P='1' then Alignment:=rvaCenter;
     if P='2' then Alignment:=rvaRight;
     RVE.ApplyParaStyle(RVS.ParaStyles.Count-1);
     ps:=RVS.ParaStyles.Count-1;
If anyone can tell me what is going on, please let me know.
Thanks,
Bruce
May be RVE is not formatted before calling ApplyTextStyle?
bswift
Problem fixed
Post by bswift »
Sergey,
You are correct. I have been using this code for years and have had no problem with it. But, this has fixed it. Thanks so much and thanks for working so hard to produce a great set of components.
Blessings,
Bruce
