I've buy TRichView but red label stay. I've run the key.reg and install bpk.
I'm using BCB6 and don't see where's the problem.
Thanks !
Well, reinstalling was not really necessary
It would be enough either to delete the old (trial) trichview files, or to remove path to them from C++Builder library paths.
(I believe you had both paths to old and to new files there, but since the path to the old files was added first, older files were listed first, and C++Builder used them instead of the new files)
