Struggling to get RTF data into RVE component
BennieC
Post by BennieC »
Hi, I have data originally saved as RTF into an interbase database. However, when I read it out I can convert it into another RichEdit component but fail to put it into a Richview component.
First I retrieved the data into a file as follows:
GetaMemoBlob(self, mySpecies.ASubSpc.CurrSubFamily, mySpecies.ASubSpc.CurrSubSpeciesID,
                       aMemotype, myFile, IsValid);
procedure GetaMemoBlob(AOwner: TComponent; SubFamily : string; SubSpeciesID : integer;
                    theMemoType : string; ThePath : string; var MemoValid : boolean);
  myQry: TSQLQuery;
  TempField: TBlobField;
  if assigned(SpeciesDBCnx) then
      myQry := TSQLQuery.create(nil);
      myQry.SQLConnection := SpeciesDBCnx;
      myQry.SQL.Clear;
      myQry.SQL.Add('SELECT * FROM MEMOS WHERE SUBSPECIES_ID = '
            + '''' + inttostr(SubSpeciesID) + '''' +
            ' AND MEMOTYPE=' + '''' + theMemoType + '''');
      myQry.open;
      if not myQry.Eof then
        MemoValid := true;
        TempField := TBlobField(myQry.FieldByName('MEMODATA'));
        TempField.SaveToFile(ThePath);
      end
        MemoValid := false;
      myQry.close;
      FreeAndNil(myQry);
I then put it into a RVE Component without success as follows:
    if IsValid then
      aRVComponent.LoadRVF(myFile);
      aRVComponent.Format;
Putting it into a RichEdit field however works fine
    if IsValid then
      aREComponent.Lines.LoadFromFile(myFile);
Could you please tell me what I am doing wrong
Bennie
      aRVComponent.Clear;
      aRVComponent.LoadR[color=red]T[/color]F(myFile);
BennieC
Still struggling
Post by BennieC »
I have converted my original RTE data into RVE format and then saved it into an interbase db (All data is being transferred to a new program and data). The code to do this was
              with GenSQLQry do
                SQL.Clear;
                SQL.Add('UPDATE MEMOS SET MEMODATA = :MEMO' +
                  ' WHERE SUBSPECIES_ID = ' + '''' + inttostr(SubSpeciesID) + '''' +
                  ' AND MEMOTYPE = ' + '''' + MemoType + '''');
//             RTE to RVE Conversion
                aRTEField := TRichEdit.Create(AOwner);
                aRVEObject := TCustomRichViewEdit.Create(AOwner);
                TBlobField(imgtable.FieldByName('Memo' + inttostr(i))).SavetoStream(Stream);
                Stream.Position := 0;
                aRVEObject.LoadRTFFromStream(Stream);
                aRVEObject.SaveRVFToStream(Stream,false);
                Params[0].LoadFromStream(Stream,ftBlob);
                Stream.Free;
                aRTEField.Free;
                aRVEObject.Free;
                  GenSQLQry.ExecSQL;
                except
                  on E: Exception do
                    MessageDlg('DataInsert Error (SubSpecies - Memos)',
                      mtWarning, [mbOK], 0);
However, now that I am reading it out in the new system, into a RVedit component, I get nothing if I use LoadRVE and sometimes partial data when I use loadRTF as shown in the code before.
Why did the original conversion not work and for some reason it apears that it stayed in RTE format. And why does load RVF not work and loadRTF only partially
Regards
Bennie
I never worked with SQL queries seriously, so I cannot tell if this code correct or no, but there are some problems.
1) Use Stream.Clear instead of Stream.Position := 0. Otherwise, RVF will be written over RTF, so it may be RVF at the beginning followed by a part of RTF - i.e. corrupted data.
2) You do not assign Style to aRVEObject. Create TRVStyle component and assign its to aRVEObject.Style
3) Some properties must be assigned to load RTF and save RVF in the best way.
aRVEObject.RTFReadProperties.TextStyleMode := rvrsAddIfNeeded;
aRVEObject.RTFReadProperties.ParaStyleMode := rvrsAddIfNeeded;
aRVEObject.Options := aRVEObject.Options + [rvoTagsArePChars];
aRVEObject.RVFOptions := aRVEObject.RVFOptions + [rvfoSaveTextStyles, rvfoSaveParaStyles].
If you have hyperlinks in RTF, you also need to process OnReadHyperlink event.
