Getting Name of HotPicture!
Tim
Post by Tim »
Hello!
I add HotPicture to the document like this:
RVE.AddHotPictureTag('Edit', EditBMP, -1, rvvaBaseline, DM.SearchQuery.FindField('StoriesID').AsInteger);
At OnJump event using follwing line of code I get Tag number of hot picture:
  ItemNo: Integer;
  RVData: TCustomRVFormattedData;
  RVE.GetJumpPointLocation(id, RVData, ItemNo);
  if RVData.GetItemStyle(ItemNo) = rvsHotPicture then
    ShowMessage('Picture ' + IntToStr(RVData.GetItemTag(ItemNo)));
Now I want to get name constant of hot picture. because I have two kind of hot picture: Edit, Note.
I want to understand does user clicked at Edit HotPicture or Note HotPicture.
Is there a way to get name constant of hot picture? :roll:
Regards
RVData.GetItemTextA(ItemNo)
Tim
Simple anothor question!
Post by Tim »
Thanks for your answer. :D
I have anothor simple question: Why TransparentBackground of RVPrint dosen't work. hwo it is possible to print a document using RVPrint withour background image. I also try FormatPages([]) without any paramateres but it dosen't work, too. :idea:
Regards
This property affects only the background color.
To remove a background bitmap from printing, call
RVPrint.rv.BackgroundBitmap := nil;
after calling RVPrint.AssignSource.
