Copy MS Word content to TRichviewEdit
King Cheung
Post by King Cheung »
I'm trying to copy content from MS Word and paste it to TRichviewEdit. In the OnPaste event, my code like this:
 str := Clipboard.AsText;
 rchvwdt.InsertTextA(str,False);
 DoDefault := false;
In this way, what i get is plain text without font info. What should i do to get text with font info?
King Cheung
Cause the pasted content mostly chinese,if i dont't add the OnPaste function, their will be some error.For example, if i copy "(有无)"from Ms Word, after i paste it to richviewedit, it will be "(无".
Why do you need to process OnPaste? TRichViewEdit can paste the content saved by MS Word automatically, without any additional code.
King Cheung
Sergey Tkachenko wrote:Why do you need to process OnPaste? TRichViewEdit can paste the content saved by MS Word automatically, without any additional code.
When i copy chinese from Ms Word to TRichViewEdit,sometimes it will be wrong.You can try it, when copy "(有无)" from MS Word to TRichViewEdit, the result will be "(无".
What version of Delphi do you use?
Please give me step by step instructions how to reproduce this problem.
Send the source doc file to richviewgmailcom
King Cheung
Sergey Tkachenko wrote:What version of Delphi do you use?
I am using Delphi 7, and the richview version is v11.0.5.FS.AS we need to paste chinese to TRichViewEdit,so unicode is the only choice.Then i add some code like this:
 rchvwdt.Clear;
  for i:= 0 to rvstyl.TextStyles.Count-1 do
    rvstyl.TextStyles[i].Unicode := True;
  rchvwdt.RTFReadProperties.UnicodeMode := rvruOnlyUnicode;
I will send you a chinese test doc, you can copy the text and paste it to TRichViewEdit,then it will cause the error.
King Cheung
Hello Sergey,
Do you test the chinese text? I really look forward to your solution!Thank you!
I tested you file - copied it from MS Word to TRichViewEdit, and it looks exactly the same.
You use an old version of TRichView, please update it and test if this problem still exists.
King Cheung
Sergey Tkachenko wrote:I tested you file - copied it from MS Word to TRichViewEdit, and it looks exactly the same.
Hello Sergey,
The problem is solved after i update the TRichView. Thank you!
