Does anyone know to read RTF page orientation(Portrait, Landscape) and Page Size(A4, A3, Letter) which is loaded in TRichView?
Regards,
Tomas
RTF page orientation and PageSize
Hello Tomas!
Try
change sources
RVRTFProps.pas
procedure TRVRTFReaderProperties.ReaderEndParsing(Sender: TObject);
{$IFDEF RICHVIEW_DPMARGINS}
if not EditFlag then begin
if Reader.RTFState.DocProps.LeftMarginTw>0 then
RVData.GetAbsoluteRootData.GetDocProperties.Values['LeftMarginMM'] :=
IntToStr(Round(Reader.RTFState.DocProps.LeftMarginTw*127/(1440*5)));
if Reader.RTFState.DocProps.TopMarginTw>0 then
RVData.GetAbsoluteRootData.GetDocProperties.Values['TopMarginMM'] :=
IntToStr(Round(Reader.RTFState.DocProps.TopMarginTw*127/(1440*5)));
if Reader.RTFState.DocProps.RightMarginTw>0 then
RVData.GetAbsoluteRootData.GetDocProperties.Values['RightMarginMM'] :=
IntToStr(Round(Reader.RTFState.DocProps.RightMarginTw*127/(1440*5)));
if Reader.RTFState.DocProps.BottomMarginTw>0 then
RVData.GetAbsoluteRootData.GetDocProperties.Values['BottomMarginMM'] :=
IntToStr(Round(Reader.RTFState.DocProps.BottomMarginTw*127/(1440*5)));
if Reader.RTFState.DocProps.PaperWidthTw>0 then
RVData.GetAbsoluteRootData.GetDocProperties.Values['PageWidthMM'] :=
IntToStr(Round(Reader.RTFState.DocProps.PaperWidthTw*127/(1440*5)));
if Reader.RTFState.DocProps.Landscape then
RVData.GetAbsoluteRootData.GetDocProperties.Values['Landscape'] := 'Yes';
{$ENDIF}
RV_DEFS.inc
{$DEFINE RICHVIEW_DPMARGINS}
and add to my control
procedure TZRVRichEdit.SetPageProps;
LeftMargin:=0;
RightMargin:=0;
If (DocProperties.Values['PageWidthMM']<>'') and (DocProperties.Values['PageWidthMM']<>'0') then
PageWidth:=MulDiv(StrToInt(DocProperties.Values['PageWidthMM']), GetDeviceCaps(Canvas.Handle, LOGPIXELSX) ,25);
If DocProperties.Values['LeftMarginMM']<>'' then
LeftMargin:=MulDiv(StrToInt(DocProperties.Values['LeftMarginMM']), GetDeviceCaps(Canvas.Handle, LOGPIXELSX) ,25);
If DocProperties.Values['RightMarginMM']<>'' then
RightMargin:=MulDiv(StrToInt(DocProperties.Values['RightMarginMM']), GetDeviceCaps(Canvas.Handle, LOGPIXELSX) ,25);
If DocProperties.Values['TopMarginMM']<>'' then
TopMargin:=MulDiv(StrToInt(DocProperties.Values['TopMarginMM']), GetDeviceCaps(Canvas.Handle, LOGPIXELSX) ,25);
If DocProperties.Values['BottomMarginMM']<>'' then
BottomMargin:=MulDiv(StrToInt(DocProperties.Values['BottomMarginMM']), GetDeviceCaps(Canvas.Handle, LOGPIXELSX) ,25);
If DocProperties.Values['Landscape'] = 'Yes' then
Orientation:=poLandscape else Orientation:=poPortrait;
if (RightMargin<>0) and (LeftMargin<>0) then begin
MaxTextWidth:=PageWidth-RightMargin-LeftMargin;
MinTextWidth:=MaxTextWidth;
call this procedure after load RTF for set properties TRV
for save properties
add Event OnSaveRTFExtra sample below
procedure TZRVRichEdit.OnSaveRTFExtra(Sender: TCustomRichView;
Area: TRVRTFSaveArea; Obj: TObject; Index1, Index2: Integer;
InStyleSheet: Boolean; var RTFCode: String);
function MMToTwips(mm: Integer): Integer;
Result := Round(mm*1440*5/127);
if Area=rv_rtfs_Doc then
RTFCode := SysUtils.Format('\paperw%d\margl%d\margt%d\margr%d\margb%d',
[MMToTwips(muldiv(MinTextWidth+LeftMargin+RightMargin,25,96)),
MMToTwips(muldiv(LeftMargin,25,96)),
MMToTwips(muldiv(TopMargin,25,96)),
MMToTwips(muldiv(RightMargin,25,96)),
MMToTwips(muldiv(BottomMargin,25,96))]);
if Orientation=poLandscape then
RTFCode :=RTFCode + '\landscape';
Try
change sources
RVRTFProps.pas
{$ENDIF}
RV_DEFS.inc
LeftMargin:=0;
RightMargin:=0;
for save properties
