Just wondering if the folowing is possible.
I have a small RTF document which is essentially a Header document.
I can load that into the Editor using LoadRTF. No problem.
I then move the cursor to the end of the Header using Last.
Now I want to load another RTF document which is basically appended to the header. LoadRTF clears the editor before loading the new docuement. Is there any way I can stop that so the next loaded doument is appended to the editor after the Header?
I read the post about appending RTF but that seemed like a somewhat different issue or am I missing something?
Cheers,
Mark
LoadRTF
