Protection of text and pictures.
Marcer
Post by Marcer »
I have a function that protect all the text in my RichView by assigning [rvprModifyProtect, rvprDeleteProtect, rvprSticking, rvprStickToTop] to every style in my RichView. Also, when my function detects a picture with « StyleNo = rvsPicture », I apply the following code :
SetItemExtraIntProperty(iItm, rvepDeleteProtect, 1);
SetItemExtraIntProperty(iItm, rvepResizable, 0);
My problem is that I can insert text between my text and my picture.
Is there a way to prevent this behavior.
Thank you.
The simplest way to protect everything is assigning RichViewEdit.ReadOnly := True.
Also, you can protect paragraph (see Options property of paragraph style).
Or, to prevent inserting something between specific items, you can use OnCheckStickingItems event.
Marcer
Post by Marcer »
Hello Sergey,
I'm currently implementing a functionality to protect the current selection. So « RichViewEdit.ReadOnly := True » and « paragraph style » are not solutions that I can consider.
On the other hand, OnCheckStickingItems is pretty much what I needed but there is a catch.
When I have two paragraph separated by a picture protected with rvprSticking and rvepDeleteProtect, OnCheckStickingItems is not fired when I write to the left or to the right of my picture, probably because of line feeds.
Do you have any recommendations to correct this problem?
It's a bug. It will be fixed in the next update.
Fixed in v14.9.1 (available for registered users)
