Lost HyperLink in RichViewEdit
Wizard
Post by Wizard »
I need edit HTML document. I Try RichViewEdit component. I LoadHTML document using TRvHtmlImporter and save it using RichViewEdit function “SaveToHTML”. It’s Work but if I insert hyperLink in Document I lost url when save it.
I find what I must use “RichViewEdit1WriteHyperlink” and “RichViewEdit1ReadHyperlink” properties. I insert code in it. It’s fix may problem, but when I paste formatted Text from clip boar program rise Error “List Out of bound”. How can I fix all my problems?
procedure TfrmRichEditForm.RichViewEdit1ReadHyperlink(Sender: TCustomRichView;
  const Target, Extras: string; DocFormat: TRVLoadFormat; var StyleNo,
  ItemTag: Integer; var ItemName: TRVRawByteString);
  lStr: String;
  lPWideChar: PWideChar;
  lPointer: Pointer;
  if DocFormat=rvlfURL then
    StyleNo :=
      rvActionInsertHyperlink1.GetHyperlinkStyleNo(RichViewEdit1);
  lStr:= (rvActionInsertHyperlink1.EncodeTarget(Target));
  New(lPWideChar);
  GetMem(lPWideChar, Length(lStr)*SizeOf(Char));
  Move(lPWideChar, lStr, Length(lStr));
  lPointer:= lPWideChar;
  ItemTag:= integer(lPointer);
procedure TfrmRichEditForm.RichViewEdit1WriteHyperlink(Sender: TCustomRichView;
  id: Integer; RVData: TCustomRVData; ItemNo: Integer;
  SaveFormat: TRVSaveFormat; var Target, Extras: string);
  lRVTag: TRVTag;
  if ItemNo >= 0 then begin
     lRVTag := RichViewEdit1.GetItemTag(ItemNo);
     if lRVTag > 0  then
       Target:= PWideChar(lRVTag);
What version of TRichView do you use?
I can see you already use TRVTag type (= String). This type was introduced when tags became strings.
But I can see that your RichViewEdit1ReadHyperlink has incorrect (old) parameters - ItemTag is Integer instead of TRVTag. It may lead to all kinds of errors (and actually, Delphi should warn you about incompatible parameter types).
It must be:
  [color=red]var StyleNo: Integer;  var ItemTag: TRVTag;[/color]
Next, if you use new version of TRichView v13.13 or newer, it is not necessary to assign OnReadHyperlink and OnWriteHyperlink.
Starting from this version, if they are not assigned, TRichView itself read and writes hyperlink targets to item tags.
You said targets are lost, so I assume you use an older version.
The best solution is upgrading to a new version.
In the new version, OnWriteHyperlink is not necessary.
OnReadHyperlink is useful only when pasting URLs (DocFormat=rvlfURL), to switch to a hypertext style.
Additionally, by default TRvHtmlImporter uses OnReadHyperlink only if you exclude rvhtmloAutoHyperlinks from its Options property. If this option is set, it saves hyperlink targets to item tags directly.
If you still want to write handlers for these events.
In OnReadHyperlink, you must not allocate any memory dynamically.
In OnWriteHyperlink, you must call RVData.GetItemTag instead of RichViewEdit1.GetItemTag.
  const Target, Extras: String; DocFormat: TRVLoadFormat; var StyleNo: Integer;
  var ItemTag: TRVTag; var ItemName: TRVRawByteString);
    StyleNo :=
      rvActionsResource.rvActionInsertHyperlink1.GetHyperlinkStyleNo(RichViewEdit1);
  ItemTag := Target;
   Target := RVData.GetItemTag(ItemNo);
Wizard
Post by Wizard »
I use RichViewEdit v14.5 and RvHtmlImporter v0.0048. I try your solutions but hyperlink still lost url.
When I use code for RichViewEdit1ReadHyperlink and RichViewEdit1WriteHyperlink as you propose i obtain errors when compile project
[dcc32 Error] E2010 Incompatible types: 'string' and 'Integer'
in RichViewEdit1WriteHyperlink
and
[dcc32 Error] E2010 Incompatible types: 'Integer' and 'string'
in RichViewEdit1ReadHyperlink
In this case you mean what I need fix source code of RichViewEdit and re build all *.bpl files ?
Bpl files must be rebuild on all TRichView updates.
If you rebuild them, does it fix the problem?
Wizard
Post by Wizard »
I have some problems with rebuilding compoents. I must deactivate directive {.$DEFINE RVOLDTAGS}. Full instraction about converting RTF into HTML I public here.
http://fk-uran.com.ua/trichviewedit-ter ... limporter/
This directive is not activated by default. It was added for simplifying support of old projects, but its using is highly not recommended.
