How to change properties for hidden text?
Jim Knopf
Post by Jim Knopf »
Hi, me again
how can I change the outfit of hidden text? Without dotted underline instead of this color gray.
Sorry, dotted underlined are hard-coded
Jim Knopf
Post by Jim Knopf »
and text color?
Color can be changed in OnApplyStyleColor event
Jim Knopf
Post by Jim Knopf »
Can you give me a hint how?
- RVEdit: Settings are 'use predefined set of styles' (necessary to protect of importet formatting)
- style No 15 in TRVStyle has options = rvteoHidden
It works but would be fine to recognize hidden text immediately as such one.
Sorry, I understand your settings but I do not understand the question.
Jim Knopf
Post by Jim Knopf »
sorry for poor explanation.
If I change text color of style 15 I can apply dark colors as clNavy or clGreen but no lighter ones, clSilver e.g.
And I don't know how to change color of hidden text by OnApplyStyleColor event.
First, I do not understand why do you need some special code or settings for hidden text, if you only have a single text style used for hidden text.
Just assign RVStyle.TextStyles[15].Color := clNavy to change its text.
OnApplyStyleColor can be used if you want to display some text with different colors, not with colors specified in Color or BackColor properties.
Something like:
procedure TMyForm.MyRVStyleApplyStyleColor(Sender: TRVStyle; Canvas: TCanvas;
  StyleNo: Integer; DrawState: TRVTextDrawStates; var DoDefault: Boolean);
  if (rvteoHidden in Sender.TextStyles[StyleNo].Options) and
    not (rvtsSelected in DrawState) then begin
    Canvas.Font.Color := clNavy;
    Canvas.Brush.Style := bsClear;
    DoDefault := False;
This code makes all hidden text color = clNavy.
Jim Knopf
Post by Jim Knopf »
The reason why I tried out an other way is, that I can't change RVStyle.TextStyles[15].Color. I can, sure, but it has no effect. May be because of I use 'use a predefined set of styles' in my rvEdit.
So I assume that the editor is searching a style as similar as possible if I assign 'hidden' to a selected text and creates a new one if it dont' find one. If the color of RVStyle.TextStyles[15] is dark (clNavy, clGreen) perhaps it is 'enough similar' and it accepts the existing style. E.g. gray or silver is not similar > makes its own new style. I hope I could explain my problem? Sorry I know it sounds a little complicated ...
Jim Knopf
Post by Jim Knopf »
But the code you posted under MyRVStyleApplyStyleColor works fine, thank you so much!
lkessler
Post by lkessler »
I too would like the option to display hidden text without the dotted underline.
Louis
