Modify the filename of the Save dialog?
I use the following code to create a new document (using another file as base):
srvActionsResource.rvActionNew1.Execute;
MainForm.ActiveEditor.RichViewEdit.LoadRVF(ExtractFilePath(ParamStr(0))+'MyFiles\'+DocName);
MainForm.ActiveEditor.Format;
MainForm.SRVTabSet1.Tabs[MainForm.SRVTabSet1.TabIndex].Text := 'My business card 1';
My problem is that when I click on Save, in the Save dialog the filename is which was set in the RvaControlPanel.DefaultFileName.
Can I set the filename each time to what I need? e.g. 'My business card 1', 'My business card 2' etc.
Thank you
Thank you
If you want to assign a file name to the editor, load it using rvActionOpen1.LoadFile:
srvActionsResource.rvActionOpen1.LoadFile(MainForm.ActiveEditor.RichViewEdit,
ExtractFilePath(ParamStr(0))+'MyFiles\'+DocName, ffiRVF);
It is slightly more complicated.
The customer wants the following:
1.choose a base document from the list (I populate a sub menu with the available base documents for him)
2.The program opens a New document
It is very important for the customer that the new documents should have a name (therefore I use MainForm.SRVTabSet1.Tabs[MainForm.SRVTabSet1.TabIndex].Text := 'My business card '+sNumber; ) but they should be in memory and not in a saved file
3.At Save the program should set the filename in the Save dialog to the same as the MainForm.SRVTabSet1.Tabs[MainForm.SRVTabSet1.TabIndex].Text
Your method
is not good for him because the *real* base document will be loaded which should not be modified any time.
Thank you
Your method
Thank you
Try
srvActionsResource.rvActionSave1.GetDoc(MainForm.ActiveEditor.RichViewEdit).FileName := DocName;
At runtime
gives me access violation...
Thank you
At runtime
Thank you
I think it because GetDoc returns nil for MainForm.ActiveEditor.RichViewEdit.
It means no document information is associated by RichViewActions with this editor.
Is srvActionsResource.rvActionNew1.Execute called for the editor which is later available as MainForm.ActiveEditor? Probably not, otherwise it should work.
As a test, I added in the ActionTestTabs demo, in the procedure TForm3.OnNewEditor, after the linethe following code:
It works - when I call Save, the default file name is 'it works.rvf'.
(however, a new tab is still called 'Untitled.rvf', because its name is assigned TForm3.rvActionSave1DocumentFileChange, and this event is called in rvActionNew1.ExecuteTarget)
srvActionsResource.rvActionNew1.ExecuteTarget(ActiveEditor.RichViewEdit);
srvActionsResource.rvActionSave1.GetDoc(ActiveEditor.RichViewEdit).FileName := 'it works.rvf';
The code you gave:
Works very well for all the tabs, except the first.
Perhaps because the first tab / editor already exists.
And If I use it like this:
MainForm.ActiveEditor.RichViewEdit.LoadRVF(ExtractFilePath(ParamStr(0))+DocName);
srvActionsResource.rvActionSave1.GetDoc(MainForm.ActiveEditor.RichViewEdit).FileName := 'it works1.rvf';
then I get get Access violation.
Thank you
The code you gave:
Thank you
