SRVPageScroll SRichViewEdit ScrollBar
devx
Post by devx »
How to change the appearance (style) ScrollBar component in SRichViewEdit and SRVPageScroll independent themes windows ScrollBar.
Scrollbars of SRichViewEdit can be customized using TSRVSkinManager component. Example can be found in Demos\ActionTestTabs\
Unfortunately, SRVPageScroll uses standard windows scrollbars. You can hide it (VScollVisible = False) and use an external TSRVScrollBar (that can be customized using TSRVSkinManager).
To update this external scrollbar, you can use VScollPos and VScrollMax properties of SRVPageScroll, its OnVScolled event, SRichViewEdit.OnPageCoutChanged event.
Alternatively, you can use VCL visual styles, if you use Delphi XE2 or newer.
