rvActionInsertTable: How to preset vertical Middle alignment
PeterPanino
Post by PeterPanino »
I use rvActionInsertTable to insert a table into RichViewEdit. Unfortunately, the cells in this table are all vertically aligned to the Top. So how can I preset this action to have all cells vertically aligned to Middle instead?
RichView 13.6.3
Delphi XE2
Windows 7 x64 SP1
PeterPanino
Typo
Sorry for the typo. Of course the action name is:
r v A c t i o n I n s e r t T a b l e
PeterPanino
Found a solution:
procedure TformHV.rvActionInsertTable1Inserting(Sender: TrvActionInsertTable; table: TRVTableItemInfo);
  i: Integer;
  for i := 0 to table.RowCount - 1 do
    table.SetRowVAlign(rvcMiddle, i);
Or is there a better way?
Using OnInserting is the only way.
You can define properties of a table itself by changing properties of TrvActionInsertTable, but if you want to change properties of rows and/or cells, use this event.
