Strange: Shortcuts don't work inside table
PeterPanino
Post by PeterPanino »
Hello! In a RichViewEdit I have a table and outside of the table some text. Some keyboard shortcuts are defined in a popup menu's items.
Now, when the caret is inside the table, then the shortcuts DON'T work.
But when the caret is outside the table, then the shortcuts DO work.
Which shortcut, for example?
PeterPanino
Solved
Nevermind, I have been using a non standard feature which worked only outside table. Now I've studied the URLs demo and use the OnJump event handler which always works well.
