Picture not visible in email
retwas
Post by retwas »
I use the last version of TRichView on Delphi XE2.
When I sent a email, picture is not visible.
For exemple, on my sign, we not see the picture.
You can see result on the attached file
Please send this email to richviewgmailcom
retwas
Post by retwas »
Sergey Tkachenko wrote:Please send this email to richviewgmailcom
Ok I will email to this adress
I received your email sample.
You simply assigned HTML to a plain text message.
Well, at least Windows Live Mail understands that this is HTML, not a plain text.
But normally, HTML emails are created in a different way. It must contain HTML and images encoded as MIME. References to images from HTML must be created in a special way.
Examples:
http://www.trichview.com/forums/viewtopic.php?t=11 - using Indy
http://www.trichview.com/forums/viewtopic.php?t=4123 - using CleverComponents
retwas
Post by retwas »
Thanks I try with mime demo but I have a problem on procedure "OnSaveImage2".
var gr: TGraphic;
    bmp: TBitmap;
  if SaveFormat<>rvsfHTML then
  if not (Graphic is TJPEGImage) and not RV_IsHTMLGraphicFormat(Graphic) then begin
    bmp := TBitmap.Create;
      [b]bmp.Assign(Graphic);[/color]
    except
I have error
impossible d'affecter tjpegimage à tbitmap
who mean, can't affect tjpegimage in tbitmap, I have same error with png ..
