how to put background image at runtime?
Sergey Hello, I would like to know how to put an image in the background of the text at run time.
thanks
thanks
To define a background picture, assign BackgroundBitmap and BackgroundStyle properties.
As for pictures on pages, there are two solutions.
1) This feature requires the newest beta version.
Insert a textbox in a header (or in a footer), insert a picture in this textbox.
Insert another picture in a header (or a footer) for even pages.
Assign RVPrint.FacingPages (or SRichViewEdit.PageProperty.FacingPages) = True.
2) Use RVPrint.OnPagePrepaint (or SRichViewEdit.OnPaintPage) event to draw pictures yourself.
There is a demo, http://www.trichview.com/support/files/crocoprint.zip , it's quite old, but I hope it still works.
I'm doing the following:
but nothing happens, what do I doing wrong?
procedure TFrmCadEditorMinutasTab.FormCreate(Sender: TObject);
procedure GetPrinterPixelsPerInch;
var DC: Cardinal;
DC := RV_GetPrinterDC;
PrinterHPixelsPerInch := GetDeviceCaps(DC,LOGPIXELSX);
PrinterVPixelsPerInch := GetDeviceCaps(DC,LOGPIXELSY);
DeleteDC(DC);
Imagem := TImage.Create(nil);
Imagem.Picture.LoadFromFile('C:\compartilhado\Imagens\adsf22.jpg');
Image1Width := Round(Imagem.Picture.Graphic.Width * PrinterHPixelsPerInch / Screen.PixelsPerInch);
Image1Height := Round(Imagem.Picture.Graphic.Height * PrinterHPixelsPerInch / Screen.PixelsPerInch);
Image2Width := Round(Imagem.Picture.Graphic.Width * PrinterHPixelsPerInch / Screen.PixelsPerInch);
Image2Height := Round(Imagem.Picture.Graphic.Height * PrinterHPixelsPerInch / Screen.PixelsPerInch);
procedure TFrmCadEditorMinutasTab.PrintImage(Canvas: TCanvas; X,Y: Integer; gr: TGraphic;
ToScreen: Boolean);
var bmp: TBitmap;
// RV_PictureToDevice understands only bitmaps
bmp := TBitmap.Create;
bmp.Assign(gr);
RV_PictureToDevice(Canvas,X,Y,gr.Width,gr.Height,@(TCustomMainPtblRVData(SRichViewEdit1.RichViewEdit.RVData).PrnSad),bmp,ToScreen,RVStyle1.GraphicInterface);
bmp.Free;
procedure TFrmCadEditorMinutasTab.SRichViewEdit1PaintPage(Sender: TObject;
PageNo: Integer; PageRect,R: TRect; Canvas: TCanvas; Prepaint,
Printing: Boolean);
inherited;
if PageNo mod 2 <> 0 then
PrintImage(Canvas,(PageRect.Left + PageRect.Right - Image2Width) div 2,(PageRect.Top + PageRect.Bottom - Image2Height) div 2,Imagem.Picture.Graphic,true)
PrintImage(Canvas,(PageRect.Left + PageRect.Right - Image2Width) div 2,(PageRect.Top + PageRect.Bottom - Image2Height) div 2,Imagem.Picture.Graphic,true);
used this in SRichViewEdit1PaintPage, this is what I want, but with the image behind the text:
with RV_PictureToDevice nothing happens:
RV_PictureToDeviceAlt(Canvas,(PageRect.Left + PageRect.Right - PIC.Height) div 2,(PageRect.Top + PageRect.Bottom - PIC.Width) div 2,PIC.Width,PIC.Height,PIC.Bitmap);
RV_PictureToDevice(Canvas,(PageRect.Left + PageRect.Right - PIC.Height) div 2,(PageRect.Top + PageRect.Bottom - PIC.Width) div 2,PIC.Width,PIC.Height,@(TPrintableRVData(SRichViewEdit1.RichViewEdit.RVData).PrnSad),PIC.Bitmap,true,RVStyle1.GraphicInterface);
For ScaleRichView, it's even simpler than for TRVPrint.
This code displays a bitmap from Image1 on even pages of SRichViewEdit1, at the top left corner of the main text area.
The picture is scaled by 0.5 (see Scale constant)
You tried adapting a code for TRVPrint, and not all was made correct.
Typecasting to TCustomMainPtblRVData is wrong, this kind on RVData exists only in TRVPrint and TRVReportHelper. ScaleRichView does not use a printer resolution explicitly, so "sad" object can be nil.
As for GraphicInterface object, and object from any RVStyle can be used, they are currently all identical.
procedure TForm3.SRichViewEdit1PaintPage(Sender: TObject; PageNo: Integer;
PageRect, R: TRect; Canvas: TCanvas; Prepaint, Printing: Boolean);
const Scale = 0.5;
if Prepaint and ((PageNo mod 2) = 0) then
PageRect.Left+SRichViewEdit1.LeftMargin100Pix,
PageRect.Top+SRichViewEdit1.TopMargin100Pix,
Round(Image1.Picture.Bitmap.Width*Scale),
Round(Image1.Picture.Bitmap.Height*Scale),
nil, Image1.Picture.Bitmap, False, SRichViewEdit1.RichViewEdit.Style.GraphicInterface);
Try this code:
In the new version, it paints below the text.
If in your version it paints above the text, all what I can suggest is upgrading.
if Prepaint then begin
Canvas.Brush.Color := clRed;
Canvas.FillRect(PageRect);
You should convert png to TBitmap.
If this picture is too large and it slows down editing, you can use Printing parameter of OnPaintPage: draw it only if Printing=True.
Sorry, I do not know how it can happen that a picture is below text on the screen but above text on printing. I cannot reproduce it. May be the problem is in your printer's driver...
sergey ok, managed to get a solution. I appreciate all the help.
My question now is another, wanted to know if the possibility of taking the function header that replicates the same text for all pages exists. I want to use only the header of page 1, for example, and would not want to use the paintpage.
it exists?
it exists?
