Equivalent to RichEdit DefAttributes
Lucian
Post by Lucian »
I am creating TRichview component at run time. What is the equivalent of RichEdit.DefAttributes, so that when a user starts editing the component will use, for example, font Tahoma size 12?
Luican
Do you use RichViewActions?
Do you use StyleTemplates?
Lucian
Post by Lucian »
Sergey Tkachenko wrote:Do you use RichViewActions?
No and no.
So, when implementing a New command, you can add a code like this:
RVStyle1.TextStyles.Clear;
with RVStyle1.TextStyles.Add do begin
  FontName := 'Tahoma';
RVStyle1.ParaStyles.Clear;
RVStyle1.ParaStyles.Add; // you can specify default paragraph properties here too
RVStyle1.ListStyles.Clear;
Lucian
Post by Lucian »
Thanks Sergey
