Specific margins for the 1st page only (not other pages)
sylvainl
Post by sylvainl »
I use a TScaleRichViewEdit (v6), with header+footer for the 1st page (PageProperty.TitlePage := True).
I would like to have specific margins for my 1st page (differents than other pages margins), programmatically.
I couldn't find how to do that, couldn't found any property (setmargins for Page 1 only)
Any idea ?
Example of what I want to do...
[Page 1]
Margins (left, top, right, bottom): 10mm 20mm 20mm 20mm
Header specific : text header 1st page
Footer specific : text footer 1st page
[Page 2,....n]
Margins (left, top, right, bottom): 10mm 15mm 10mm 15mm
Header normal : text header
Footer normal : text footer
The only idea I had was : because I have a 1st page header specific, maybe I can write in it (addtexnla, addnla , ... in SubDocuments[srvhftFirstPageHeader]) until I have the height I need for my page 1 top-margin (= header 1st page Height, in my case)... but could manage how to check the height :(
Thanks in advance for your help, guys.
SylvainL
Sorry, it is not supported yet.
It requires implementations of sections of documents (parts of documents having their own page settings). It is planned for future, but not very near future, sorry.
sylvainl
Post by sylvainl »
Arg...
but ok, I understand.
So I will just do differently meanwhile, and just play with the SRve.SubDocuments[srvhftFirstPageHeader]
If I had some linebreak at the end, it can do the job.
But there is one problem (bug?), when I do
SRve.SubDocuments[srvhftNormalHeader].AddNL('test',0,0);
I need to write
SRve.ReFormat;
And the modification of header height is effective
But when I do
SRve.SubDocuments[srvhftFirstPageHeader].AddNL('test',0,0);
and
SRve.ReFormat;
But nothing happen, the 1st page header height doesn't change
Thanks for your help
SylvainL
